muso Member 11 Member For: 9y 8m 16d Gender: Male Location: South Australia Posted 12/07/14 02:50 PM Share Posted 12/07/14 02:50 PM Today my car stopped and would not crank let alone start. The RAA came and found that the 15 amp injector fuse (fuse #30 cabin fuse box) blew each time he replaced it. The engine would crank when bypassing the ignition but would not fire. He ordered a tow truck and it was towed home. The car is dual fuel and has liquid lp gas injection. I removed the lp gas system fuses then replaced the 15 amp inj fuse again and it cranked and started, it ran for a short while then stopped, it had blown the fuse again. There was also an unusual burning smell from under the bonnet, also recently I've noticed that the ICC screen goes dim every now and then but probably unrelated, the battery is new and alternator is fine as are the battery terminals. But something is going on with the fuel injector wiring to blow fuses, has anyone else experienced this? Link to comment Share on other sites More sharing options...
barnz Member 3,047 Member For: 10y 4m 8d Gender: Male Location: Brisbane Posted 12/07/14 09:58 PM Share Posted 12/07/14 09:58 PM (edited) Bit weird, never heard of or experienced this problem but I would unplug all your injectors and see if it cranks without blowing, plugging one back in at a time. Shut it down straight away if it starts, running on 1 or 2 injectors cant be good. If it even runs.You can try holding your foot flat to the floor while cranking, the car wont start im just not sure whether it doesn't start cause of an ignition cut or fuel, if its the later it may not be useful in your situation.If it still blows with them all unplugged you will have to start looking at the harness for damage, could even be the pcm itself I suppose.If you have a multimeter and can follow wiring diagrams ok you could meter each injectors at the connector to the pcm and see if one has shorted or even just gives a different reading to all the others. Edited 12/07/14 10:07 PM by barnz 2 Link to comment Share on other sites More sharing options...
genuine honest person Member 2,769 Member For: 10y 2m Gender: Male Location: near brisbane Posted 12/07/14 10:34 PM Share Posted 12/07/14 10:34 PM good luck mate ,sounds like its a hard one to work out where the problem is starting from .keep us posted .all the best Link to comment Share on other sites More sharing options...
muso Member 11 Member For: 9y 8m 16d Gender: Male Location: South Australia Posted 12/07/14 10:54 PM Author Share Posted 12/07/14 10:54 PM Cheers guys I'll have a look today, mechanic can't look at it until next week so until then I'll have to either buy a cheap 2nd car (a bit drastic) or borrow one Being a one car one driver family sucks! Link to comment Share on other sites More sharing options...
muso Member 11 Member For: 9y 8m 16d Gender: Male Location: South Australia Posted 15/07/14 07:59 AM Author Share Posted 15/07/14 07:59 AM Mobile Auto electrician looked at it yesterday but didn't have time to pull out upper inlet manifold to get a good look. Last night I removed the upper inlet manifold to gain access to all the injector wiring. Couldn't see any evidence of short circuits which would be bad enough to blow a fuse and give off a burning smell. The main loom behind the upper inlet manifold had been rubbing against the air cond pipe assembly where it goes thru the firewall on the passenger side. while the aluminium pipe had a 'dent' in it from the rubbing the actual loom still had hard grey plastic conduit with no evidence of burning or shorting. I will put some black foam AC insulation around the pipeTonight I checked coil packs and cleaned some oil which was in #2 coil pack spark plug area but didn't find any evidence of burnt/shorted wiring. Put new 15 amp fuse in and it blew after it cranked for a few seconds.Then I unplugged all the petrol injector connectors and cranked it.......no problems cranks repeatedly without blowing the fuse......so I then plugged each petrol injector connector back one at a time and it cranked with no issues (I didn't crank for long I don't want it firing without the upper inlet manifold on). It cranked without blowing the fuse when I connected each one........but it's now confusing because it didn't blow the fuse at all with all 6 injector connectors back on :( But it now cranks no problems without fuse blowing and would probably start and be driveable......but the mobile auto elec is looking at it again tomorrow.Perhaps there was a short with one of the petrol injector looms which I temporarily 'fixed' by unplugging them all. All this testing was done with the LPG fuses removed to keep that out of the equation.....it starts on petrol anyway and cannot be started on gas even in an emergency. But I want the problem found and fixed before I put it back on the road........otherwise it could break down again :( Link to comment Share on other sites More sharing options...
muso Member 11 Member For: 9y 8m 16d Gender: Male Location: South Australia Posted 16/07/14 11:18 PM Author Share Posted 16/07/14 11:18 PM Found it.....it's an intermittent short in the wiring loom under the inlet manifold :( So out comes the inlet manifold......fun times. 2 Link to comment Share on other sites More sharing options...
barnz Member 3,047 Member For: 10y 4m 8d Gender: Male Location: Brisbane Posted 16/07/14 11:28 PM Share Posted 16/07/14 11:28 PM Glad you found the issue mate, just taking the upper manifold off would be enough wouldn't it? Link to comment Share on other sites More sharing options...
muso Member 11 Member For: 9y 8m 16d Gender: Male Location: South Australia Posted 17/07/14 11:55 AM Author Share Posted 17/07/14 11:55 AM I've already taken the upper manifold off myself but today the auto electrician said he wanted to get the loom out completely. I will look at it on the weekend. You can hear the spark when you move the loom around then the fuse blows. If I look at it at night I may be able to see the spark.....all I need is darkness, good eyes and 50,000 15 amp fuses I'm also looking for a cheap car to get me around while I'm fixing the XR6T, I have a loan car some nice people lent me but it has no brake lights so I avoid driving it....it also blows fuses...the brake light fuse Link to comment Share on other sites More sharing options...
JVK Silver Donating Members 751 Member For: 18y 3m 10d Gender: Male Location: North West Hot Hell,VIC Posted 17/07/14 08:47 PM Share Posted 17/07/14 08:47 PM Use a circuit breaker instead of fuses, Much easier and quicker to find the root cause. Link to comment Share on other sites More sharing options...
muso Member 11 Member For: 9y 8m 16d Gender: Male Location: South Australia Posted 19/07/14 01:03 PM Author Share Posted 19/07/14 01:03 PM (edited) I've isolated it down to a plug which comes out of the loom and connects to #1 petrol injector, this plug literally sits against the thermostat so it would get hot. If I keep that plug away from metal or disconnect it the fuse doesn't blow.....at night you can see the spark as it shorts out.JVK where can I get one of these circuit breakers? Could I use a multimeter? Edited 19/07/14 01:04 PM by muso Link to comment Share on other sites More sharing options...
