MA91CK billet turbos and weathered engines dont mix Donating Members 1,346 Member For: 13y 1m 28d Gender: Male Location: Wollongong Posted 16/06/14 11:59 PM Author Share Posted 16/06/14 11:59 PM Basic'sAir and Fuel supply (can you check fuel pressure)Air leaks that would allow unmetered air into the engineBattey condition/Voltage when hot02 sensor conditionOr skip the guessing games and pull the codes and work from there.Possibly O2, might be worth replacing when I stick the new dump on, will check for codes tonight and check for air leaks too Link to comment https://www.fordxr6turbo.com/forum/topic/88528-not-making-full-boost-hard-start-when-warm/page/2/#findComment-1478963 Share on other sites More sharing options...
MA91CK billet turbos and weathered engines dont mix Donating Members 1,346 Member For: 13y 1m 28d Gender: Male Location: Wollongong Posted 16/06/14 11:59 PM Author Share Posted 16/06/14 11:59 PM Basic'sAir and Fuel supply (can you check fuel pressure)Air leaks that would allow unmetered air into the engineBattey condition/Voltage when hot02 sensor conditionOr skip the guessing games and pull the codes and work from there.Possibly O2, might be worth replacing when I stick the new dump on, will check for codes tonight and check for air leaks too Link to comment https://www.fordxr6turbo.com/forum/topic/88528-not-making-full-boost-hard-start-when-warm/page/2/#findComment-1478964 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 9m 27d Gender: Male Location: Perth Posted 17/06/14 12:02 AM Share Posted 17/06/14 12:02 AM also check for pre 02 sensor exhaust leaks. If there are no codes leading to obvious issues, look for any issues that would cause the pcm to believe the engine is receiving less air than it is. Link to comment https://www.fordxr6turbo.com/forum/topic/88528-not-making-full-boost-hard-start-when-warm/page/2/#findComment-1478966 Share on other sites More sharing options...
Peppy_t92 Silver Donating Members 748 Member For: 12y 3m 17d Gender: Male Location: Liverpool Posted 17/06/14 12:11 AM Share Posted 17/06/14 12:11 AM To add to the topic.. This car was tuned by a workshop with sct, it was over boosting and detonating, plus the LTFT were around the 18 mark, this hard start problem was happening even with the sct tune.. So I said I would have a look...The tune was very ordinary, (and that's coming from me, with little tuning experience)I sucked out the custom tune and the standard tune... I modified the standard tune as if it were my own, I adjusted the injector scaling and got it to a stage were it was boosting at a slow but steady 9-10psi, softened the timing so there was no detonation just so the car was drivable as we only had a couple of hours to look at it... I'm thinking that the base tune that I got from the x3 may not be the correct base file for the car, may be similar but not exact? Is this a possibility?When we both have some free time I'll have to do some logs while this is happening to determine what it could be 1 Link to comment https://www.fordxr6turbo.com/forum/topic/88528-not-making-full-boost-hard-start-when-warm/page/2/#findComment-1478970 Share on other sites More sharing options...
MA91CK billet turbos and weathered engines dont mix Donating Members 1,346 Member For: 13y 1m 28d Gender: Male Location: Wollongong Posted 17/06/14 12:13 AM Author Share Posted 17/06/14 12:13 AM Yeh may I add this has nothing to do with you're tuning joe, this has been happening since I got the car. Since you tuned it, it's better, just still there. I'm hoping it's just in the tune and we can find something! Link to comment https://www.fordxr6turbo.com/forum/topic/88528-not-making-full-boost-hard-start-when-warm/page/2/#findComment-1478972 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 9m 27d Gender: Male Location: Perth Posted 17/06/14 12:14 AM Share Posted 17/06/14 12:14 AM Basic'sAir and Fuel supply (can you check fuel pressure)Air leaks that would allow unmetered air into the engineBattey condition/Voltage when hot02 sensor conditionOr skip the guessing games and pull the codes and work from there.also check for pre 02 sensor exhaust leaks. If there are no codes leading to obvious issues, look for any issues that would cause the pcm to believe the engine is receiving less air than it is.Tune issue/ Link to comment https://www.fordxr6turbo.com/forum/topic/88528-not-making-full-boost-hard-start-when-warm/page/2/#findComment-1478973 Share on other sites More sharing options...
MA91CK billet turbos and weathered engines dont mix Donating Members 1,346 Member For: 13y 1m 28d Gender: Male Location: Wollongong Posted 17/06/14 12:18 AM Author Share Posted 17/06/14 12:18 AM I really hope so! Just need to give peppy more than an hour and 3 runs to work things out. Managed to have the car running heaps better after even that amount of time,.. So if it is tune I'm sure we will be able to sus it out. I'll try to eliminate any other possibility before though 2 Link to comment https://www.fordxr6turbo.com/forum/topic/88528-not-making-full-boost-hard-start-when-warm/page/2/#findComment-1478976 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 9m 27d Gender: Male Location: Perth Posted 17/06/14 12:20 AM Share Posted 17/06/14 12:20 AM Post your tune up Joe so we can take a look. Link to comment https://www.fordxr6turbo.com/forum/topic/88528-not-making-full-boost-hard-start-when-warm/page/2/#findComment-1478977 Share on other sites More sharing options...
Peppy_t92 Silver Donating Members 748 Member For: 12y 3m 17d Gender: Male Location: Liverpool Posted 17/06/14 12:26 AM Share Posted 17/06/14 12:26 AM Sorry guys, I didn't refresh the page before writing my response.. But yes they are all things I/we will be checking when we get around to it.. I know it must be extremely annoying so like I said at the beginning I will be doing all I can to help and it we will both learn in the process 1 Link to comment https://www.fordxr6turbo.com/forum/topic/88528-not-making-full-boost-hard-start-when-warm/page/2/#findComment-1478978 Share on other sites More sharing options...
Peppy_t92 Silver Donating Members 748 Member For: 12y 3m 17d Gender: Male Location: Liverpool Posted 17/06/14 12:27 AM Share Posted 17/06/14 12:27 AM Will do.. I'll have to do it once on my laptop Link to comment https://www.fordxr6turbo.com/forum/topic/88528-not-making-full-boost-hard-start-when-warm/page/2/#findComment-1478979 Share on other sites More sharing options...
