Romulus Donating Members 1,279 Member For: 19y 3m 15d Location: Perth Posted 28/09/20 10:01 AM Share Posted 28/09/20 10:01 AM (edited) The most common issues are diff bushes, front and rear. Rarely is the '3rd' diff bush in the front replaced, on the drivers side. Also, the radius arm bushes cause problems, these should be replaced as well. Check out the upper control arm bushes and inner lower control arm bushes, if these are worn you'll get a pulsating while braking, typical of cars fitted with the larger brakes and Brembos. Rear problematic on FG Falcons. Then there's the usual centre bearing, the rubber joint between the trans and driveshaft and uni joints. It could be a combination of all these items, a couple or one. You'll need to troubleshoot, throwing parts at it will usually lead to a fix. Edited 28/09/20 10:04 AM by Romulus 1 Link to comment Share on other sites More sharing options...
