Chilly New Member 2 Member For: 5y 10m 4d Posted 13/06/18 02:35 PM Share Posted 13/06/18 02:35 PM Hi all, not sure if this helps but when the engine mounts were gone in my Territory it was vibrating at idle too especially when cold...... On a separate occasion I was experiencing vibrations under load while driving. I was fed up with it so got under the car and began looking around rear diff/suspension area ( as had previously replaced all diff and control arm bushes), I noticed a shiny section on the sub frame that mounts the diff and suspension to body near the exhaust pipe where paint was worn off. While it was parked either engine off or at idle it seemed to have about 10mm clearance but under load was twisting just enough to move closer ever so slightly to rub against this frame. Replaced hanger rubbers and slightly tweaked the metal brackets, managed to get almost a fingers gap and a bit of a touching up with paint so the frame doesn't rust and it was sweet...... Not sure if that is your issue but worth a quick look. Follow exhaust at rear of car where it loops around subframe and look for any possible contact spots, mine was rubbing just after the first muffler where it first bends up then back down again over subframe.... Good luck.:) Link to comment Share on other sites More sharing options...
David M Inactive Members 1 Member For: 17y 6m 16d Posted 05/08/18 10:39 AM Share Posted 05/08/18 10:39 AM Had a vibration problem under load 90 to 110 k, re-balanced the tail shaft, better but not fixed. Fitted new lower front arms (excessive play) and fitted new front Cv shafts (boots split and rattly). Found one Cv roller bearing collapsed (L/h side inner). Now all vibrations gone. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,281 Member For: 16y 7d Gender: Male Location: Melbourne Posted 05/08/18 12:08 PM Share Posted 05/08/18 12:08 PM Well done on fixing the problem and having only a single post in your 11year membership on this forum. Solid effort 1 Link to comment Share on other sites More sharing options...
Chilly New Member 2 Member For: 5y 10m 4d Posted 05/08/18 10:42 PM Share Posted 05/08/18 10:42 PM Wow you got nothing better to do than make comments on other people's membership, go get a real life. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,281 Member For: 16y 7d Gender: Male Location: Melbourne Posted 06/08/18 12:04 AM Share Posted 06/08/18 12:04 AM it's a compliment, mate, don't stress so much. Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 21d Gender: Male Location: Perth Posted 06/08/18 04:01 AM Share Posted 06/08/18 04:01 AM Hey Keith, you get a real life yet??? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,281 Member For: 16y 7d Gender: Male Location: Melbourne Posted 06/08/18 04:23 AM Share Posted 06/08/18 04:23 AM I dunno, mate... hard to judge your own life Link to comment Share on other sites More sharing options...
Rab WOT? Moderating Team 10,980 Member For: 11y 1m 23d Gender: Male Location: Frankston, 3199 Posted 06/08/18 04:37 AM Share Posted 06/08/18 04:37 AM You're in a lucky place Keith - heaps here who can judge it for you Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,105 Member For: 9y 2m 19d Gender: Male Location: South Australia Posted 06/08/18 04:41 AM Share Posted 06/08/18 04:41 AM Just as I finished writing this up @Rab... I'll judge ya K31th Roof over ya head✔Food in the fridge ✔Lifts weights ✔Gets laid ✔ What else do ya need apart from fixing ya car? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,281 Member For: 16y 7d Gender: Male Location: Melbourne Posted 06/08/18 04:57 AM Share Posted 06/08/18 04:57 AM cheers guys I'd say I have a life, by what puffster has said here . Link to comment Share on other sites More sharing options...
