Kosij Donating Members 2,045 Member For: 12y 8m 15d Gender: Male Posted 11/05/14 01:56 PM Share Posted 11/05/14 01:56 PM (edited) Good that you fixed it BUT keep in mind if anything similar happens remove the coils and sell them on feebay for any $ you can get. Then go genuine nothing beats genuine, fraud spend millions & millions of dollars on R&D so I assume they no what's good and what's sh*t Good that it's fixed though. Edited 11/05/14 01:57 PM by Kosij Link to comment Share on other sites More sharing options...
Phoon508 Member 188 Member For: 11y 4m 17d Posted 11/05/14 09:58 PM Share Posted 11/05/14 09:58 PM (edited) Except for diff bushes. They sure did f*ck up there Edited 11/05/14 09:58 PM by Phoon508 3 Link to comment Share on other sites More sharing options...
FiftyOne Bronze Donating Members 1,145 Member For: 10y 9m 24d Gender: Male Posted 12/05/14 10:58 AM Author Share Posted 12/05/14 10:58 AM Ok, maybe not so fixed. Boost gauge is still on the blink. That said, I still think the new coils are good Link to comment Share on other sites More sharing options...
Bez F6 Member 2 Member For: 15y 7m 23d Posted 12/05/14 01:09 PM Share Posted 12/05/14 01:09 PM Another possibility is that your battery is nearly stuffed or has a poor connection. I have a BF Typhoon, I had a couple of occasions years ago where weird things happened, including speedo & odo not working from startup, but if I stopped and restarted the car would come good again. Even though the battery was capable of starting the car, it's low voltage during start would cause the computers not to boot up properly. New battery and problem fixed. I don't recall this ever causing the boost gauge to stop working, but worth a thought. Easy enough to check the condition of your battery, and definitely time for a new one if it's becoming a bit slow to crank/start.Good luck with it. Link to comment Share on other sites More sharing options...
Kosij Donating Members 2,045 Member For: 12y 8m 15d Gender: Male Posted 12/05/14 01:33 PM Share Posted 12/05/14 01:33 PM What sort of boost gauge? Pics? Link to comment Share on other sites More sharing options...
FiftyOne Bronze Donating Members 1,145 Member For: 10y 9m 24d Gender: Male Posted 12/05/14 02:22 PM Author Share Posted 12/05/14 02:22 PM Stock OEM typhoon gauge. Battery is approx 3 years old, has more CCA's than the manufacturers spec. It does seem a little hard to crank in the mornings? Today I had to go for the button twice in fact Link to comment Share on other sites More sharing options...
Bez F6 Member 2 Member For: 15y 7m 23d Posted 13/05/14 02:57 AM Share Posted 13/05/14 02:57 AM That sounds about how mine was when it was causing issues. It never left me stranded but a bit slower to start. Another thing that may help but won't fix it is to wait til all the dash warning lights have cycled after turning the ignition on but before hitting the start button. I'm not normally patient like that - just turn the key and go straight for the start.Relates back to the computers booting up properly, if they are up and running before the starter is engaged, they don't experience the voltage drop during the seemingly more critical boot-up phase. Link to comment Share on other sites More sharing options...
Nich2134 New Member 0 Member For: 4y 10m 12d Posted 13/06/19 01:34 AM Share Posted 13/06/19 01:34 AM Anyone able to help? I own a 03 Ba xr6 and the I have recently disconnected the battery and once I connected it back up my Speedo and rev count doesn’t work? Any ideas to why? Link to comment Share on other sites More sharing options...
El Andrew Gold Donating Members 2,019 Member For: 9y 3d Gender: Male Location: Canberra ACT Posted 13/06/19 01:57 AM Share Posted 13/06/19 01:57 AM Could be worth disconnecting and reconnecting again, and grabbing a multimeter to check all of your fuses. Link to comment Share on other sites More sharing options...
FiftyOne Bronze Donating Members 1,145 Member For: 10y 9m 24d Gender: Male Posted 14/06/19 03:48 AM Author Share Posted 14/06/19 03:48 AM Bit of an old thread here but I did find the coils assisted in fixing the issues. I had also found a ground wire around the front of the bay which wasn't secured correctly, so after cleaning it & torquing it back down all has been well ever since. 1 Link to comment Share on other sites More sharing options...
