JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 20d Gender: Male Location: Adelaide Posted 27/05/14 12:20 PM Share Posted 27/05/14 12:20 PM Keep starting it but flood it with "start ya bastard" first ! Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 24d Gender: Male Location: Perth Posted 27/05/14 12:38 PM Share Posted 27/05/14 12:38 PM Agree with Ratter , sounds serious. Time for strip down. Sump off, which means engine out or lower front crossmember. Either way, get your wallet out. Link to comment Share on other sites More sharing options...
ricky Member 39 Member For: 10y 2m 4d Posted 27/05/14 12:40 PM Author Share Posted 27/05/14 12:40 PM if it's locked up, then there could be some serious damage in thereYeh not shore. The guy at high torque has done a few that have jammed the timing chain without Any issues except pump swap overs. That's why he reckons it's not starting. Will have to wait and see. All the spark plugs are good so atleast there's no holes in the pistons. Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 24d Gender: Male Location: Perth Posted 27/05/14 12:44 PM Share Posted 27/05/14 12:44 PM But seriously rocker cover off and take a look Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,117 Member For: 9y 2m 21d Gender: Male Location: South Australia Posted 24/11/21 02:36 AM Share Posted 24/11/21 02:36 AM Split pumps ay?! I guess I musta missed this thread Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,292 Member For: 16y 10d Gender: Male Location: Melbourne Posted 24/11/21 02:40 AM Share Posted 24/11/21 02:40 AM well you weren't even a member when this thread was started or last replied to haha Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 20d Gender: Male Location: Adelaide Posted 24/11/21 02:48 AM Share Posted 24/11/21 02:48 AM My post was super helpful though …. 🙃 Link to comment Share on other sites More sharing options...
Tom Tucker Donating Members 614 Member For: 4y 9m 20d Posted 25/11/21 07:57 PM Share Posted 25/11/21 07:57 PM While I'm here... I uncovered a weird wear pattern on my oil pump when I got the engine built. Motor had billet gears installed into the stock housing, and the gears had etched a series of circular grooves into the cast side of the housing. Maybe some sort of foreign debris got between the gear and the housing. Or somehow the gear just started eating into the housing. New motor has new OEM housing with new billet gears and backing plate, but I can now see the virtues of complete replacement billet or steel units. The standard housing isn't great Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,117 Member For: 9y 2m 21d Gender: Male Location: South Australia Posted 25/11/21 10:41 PM Share Posted 25/11/21 10:41 PM Mine was fine for ages when the rev limit was 7000rpm. I raised it and the oil pump failed. The engine saw 7500rpm a handful of times and 7700 just a few times. I used a billet alloy backplate, billet gears, opened up relief port, various smoothing to reduce/prevent cavitation and had an adjustable relief with a stock spring that had 5 turns into it. I've seen those marks in a stock housing with stock gears and I've seen the housing with no marks. They must suck sh*t through them. Link to comment Share on other sites More sharing options...
Tom Tucker Donating Members 614 Member For: 4y 9m 20d Posted 27/11/21 12:31 AM Share Posted 27/11/21 12:31 AM I'm a convert to full steel. But on my next engine build Link to comment Share on other sites More sharing options...
