PookeyMaster Donating Members 1,531 Member For: 13y 4m 5d Gender: Male Location: Parramatta, NSW Posted 10/02/14 12:29 PM Share Posted 10/02/14 12:29 PM Not sure where this one should go, it doesn't really fit anywhere. So nothing is coming out of my windscreen washer nozzles (FG MkII). There's definitely fluid in the container, it was low so I filled it up but it definitely wasn't empty. I can hear the pump working, at least it sounds like its working but nothing comes out of the nozzles. I didn't like to keep pulling the lever for too long, I was afraid it might burn out the motor. I do remember reading something similar and it was a common fault but I can't find the thread. I seem to remember it being a pain in the arse to get to whatever needed fixing but it wasn't actually hard to fix...just wondering if its easy enough to fix before I take it to Ford instead (still under warranty). Link to comment Share on other sites More sharing options...
tobylee Member 120 Member For: 10y 8m 12d Posted 10/02/14 12:47 PM Share Posted 10/02/14 12:47 PM I've had the nozzles block up in other cars. Have you tried using a small pin to see if they're blocked? Link to comment Share on other sites More sharing options...
Never had any say Panda I <3 Floods Silver Donating Members 11,198 Member For: 12y 8m 24d Gender: Male Location: South West QLD Posted 10/02/14 12:50 PM Share Posted 10/02/14 12:50 PM (edited) Never played on a MKII.. Check there is water in the line that runs to the nozzle.. If there is stick a pin down the squirter I have seen gunk in them a few times.. But I've also had luck running water water through it to clear it out.. Mixed with a bit of decent cleaner (like exit mould or something) just incase there was some mould or something funky blocking the line.. Edit: jut read warranty.. Try the pin.. If that doesn't work let ford fix it.. Edited 10/02/14 12:51 PM by Slightly Depressed Panda Link to comment Share on other sites More sharing options...
matsfgxr6turbo Member 388 Member For: 14y 2m 19d Posted 10/02/14 01:05 PM Share Posted 10/02/14 01:05 PM I had the same thing on my fg and it was the motor got it fixed under warranty though.Just tell them its not working and to fix it bitches. Link to comment Share on other sites More sharing options...
barnz Member 3,047 Member For: 10y 5m 5d Gender: Male Location: Brisbane Posted 10/02/14 01:21 PM Share Posted 10/02/14 01:21 PM Mine have done it twice and its not the nozzles which I have cleaned, ford "fixed" it.. was okay for about a week then the drivers one stops again, hose was full of crap, like little sticks and stuff. Apparently ford just use a bucket of water from the local creek/dam to fill your washer bottle.<br /><br />Sent from my Nexus 7 using Tapatalk<br /><br /> 2 Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 18y 7m 2d Gender: Male Location: Perth Posted 10/02/14 01:25 PM Share Posted 10/02/14 01:25 PM Algae build up on the pump inlet screen Link to comment Share on other sites More sharing options...
PookeyMaster Donating Members 1,531 Member For: 13y 4m 5d Gender: Male Location: Parramatta, NSW Posted 11/02/14 03:35 AM Author Share Posted 11/02/14 03:35 AM Thanks guys, I shall try the tips when I get home from work. As for the algae build up, is there any way to stop it? Any sort of chemical we can add to stop it growing that isn't going to also ruin the pump or washer blades? Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 18y 7m 2d Gender: Male Location: Perth Posted 11/02/14 03:41 AM Share Posted 11/02/14 03:41 AM Clean it out and add a small amount of bleach (like 1/3 a capful) and run either distilled water or tap water and washer fluid. Link to comment Share on other sites More sharing options...
freeze_dk I am dissatisfied with my current employment situation Donating Members 8,610 Member For: 17y 6m 28d Gender: Male Posted 11/02/14 03:51 AM Share Posted 11/02/14 03:51 AM I just normally pull the hose off the back of the squirter and press the trigger to see if that's ok Link to comment Share on other sites More sharing options...
FG2012XR6T New Member 24 Member For: 10y 1m 21d Gender: Male Location: Perth Posted 18/02/21 09:52 AM Share Posted 18/02/21 09:52 AM Any ideas how to remove/replace the nozzles without removing the complete full length panel that they plug into , 2012 XR6T FG model One of mine broke off during attempted removal/cleaning Cheers Link to comment Share on other sites More sharing options...
