XtRmn8 570Nm @1800rpm Donating Members 2,441 Member For: 20y 7m 3d Gender: Male Location: Perth, WA Posted 06/01/14 11:08 AM Share Posted 06/01/14 11:08 AM Good work mate, car look great. OEM battery is rubbish, I replaced mine well before it left me stranded. Link to comment Share on other sites More sharing options...
GOODY Member 19 Member For: 14y 2m 24d Gender: Male Posted 06/01/14 09:54 PM Share Posted 06/01/14 09:54 PM I just use the Mothers brand from Supercheap. More case of how often rather than brand. The car gets a full buff and polish every 3 to 4 months and I go over it with the spray on wax after every wash which is fortnightly or after a long trip.20x9 +32 with 245/35 on the front. HTG 345mm. Will just touch near full lock going up driveways if I am not careful, otherwise fine20x10 +40 with 285/30 on the rear. HTG 335-340 depending on fuel, guards rolled and pumped 5mm. No problems so far...Only it is now off the road cause the battery dropped a cell, I may have killed it with the stereo while doing the work on it...oem less than 2 yrs oldThanks for the info, similar sizes to what I'm looking for and the fitment looks spot on Link to comment Share on other sites More sharing options...
rob2489 Member 18 Member For: 13y 3m 30d Gender: Male Posted 06/01/14 11:29 PM Share Posted 06/01/14 11:29 PM I just use the Mothers brand from Supercheap. More case of how often rather than brand. The car gets a full buff and polish every 3 to 4 months and I go over it with the spray on wax after every wash which is fortnightly or after a long trip.20x9 +32 with 245/35 on the front. HTG 345mm. Will just touch near full lock going up driveways if I am not careful, otherwise fine20x10 +40 with 285/30 on the rear. HTG 335-340 depending on fuel, guards rolled and pumped 5mm. No problems so far...Only it is now off the road cause the battery dropped a cell, I may have killed it with the stereo while doing the work on it...oem less than 2 yrs old.I hope you didn't mind I used your car as a screen saver, mines in the process at the moment same colour combo about to lower it then wheels, brakes ect..great choice bud looks fantastic. 1 Link to comment Share on other sites More sharing options...
