turbotrana Member 2,586 Member For: 21y 25d Gender: Male Posted 05/12/13 08:48 AM Share Posted 05/12/13 08:48 AM I am looking for a set of rims for my White FG G6e. I've ruled out all the ebay rims and anything with the 73mm centre hub cause I reckon alot of these cheap rims are dangerous.I am considering a factory Ford Mustang rim and reckon I can get them to fit.Choice for the rears are (this is easy)19 x 9 with 42mm offset (fit no problem)19 x 9.5 with 45 offset (shim out the rear suspension blade a little and should fit)19 x 10 with either 47.5 or 51mm offset (modify rear suspension blade to make fit)Choice for front19 x 9 with 42mm offset. (need 12mm hubcentric spacer and longer studs)19 x 9 with 42mm offset (get wheel narrowed by 12.5mm, I know of a place overseas that has certification to narrow and widden wheels). This will give a 19 x 8.5 with 30 offsetTHis way I get a factory wheel made to a high standard, with the correct centre hole of 70.5 mm.Look up Ford Racing wheels Mustang and there are a good range of rims to chose from. Link to comment Share on other sites More sharing options...
Pazzo Donating Members 11,132 Member For: 13y 6m 2d Gender: Male Posted 05/12/13 09:27 AM Share Posted 05/12/13 09:27 AM (edited) Are mustang wheels the same stud pattern in 5x114:3? Edited 05/12/13 09:27 AM by Pazzo Link to comment Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 21y 25d Gender: Male Posted 05/12/13 09:50 AM Author Share Posted 05/12/13 09:50 AM Yes, same bolt pattern Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 16y 5m Gender: Male Location: Probably above atmospheric pressure Posted 05/12/13 11:06 AM Share Posted 05/12/13 11:06 AM Simon at XFT had some on his car for a while (or still does). Looked cool from memory, I'll see if I can dig up a pic. Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 16y 5m Gender: Male Location: Probably above atmospheric pressure Posted 05/12/13 11:54 AM Share Posted 05/12/13 11:54 AM Link to comment Share on other sites More sharing options...
Kanga New Member 8 Member For: 5y 6m 30d Posted 25/09/18 06:30 AM Share Posted 25/09/18 06:30 AM https://www.wheel-size.com/ show FG have centre bore of 73.1 Is this correct ? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,303 Member For: 16y 14d Gender: Male Location: Melbourne Posted 25/09/18 08:32 AM Share Posted 25/09/18 08:32 AM this post answers your question -> https://www.fordxr6turbo.com/forum/topic/71373-hub-centric-rings-or-bcl/?do=findComment&comment=1051769 Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 28d Gender: Male Location: Perth Posted 25/09/18 09:40 AM Share Posted 25/09/18 09:40 AM Good info Keith. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,303 Member For: 16y 14d Gender: Male Location: Melbourne Posted 25/09/18 09:48 AM Share Posted 25/09/18 09:48 AM cheers, double-R Link to comment Share on other sites More sharing options...
Kanga New Member 8 Member For: 5y 6m 30d Posted 25/09/18 09:23 PM Share Posted 25/09/18 09:23 PM Hi guys, I am now more confused ! I thought if a wheel had a 73.1mm centre bore it would fit my FGX. I.e. If I were to put those staggered Mustang wheels on with centre bore of 70.5mm I would have to get the rims centre bore machined to 73.1mm. Am I reading this wrong ? Link to comment Share on other sites More sharing options...
