milk Member 6 Member For: 12y 10m 4d Posted 25/09/13 01:39 PM Share Posted 25/09/13 01:39 PM I'm trying to fit a 1000hp cooler in my fg xr6t but it doesn't seem to be fitting properly. I've read that some of you had to bend and cut some things that arn't in the instructions given. The top of the cooler hits the a/c pipe and the picture that's in the instructions doesnt have the bent my pipe mine does. This is what the one in the instructions looks like https://www.plazmaman.com/upload/dazcvrrlekmmllwz.jpg (in the top right hand corner of the cooler). Any tips? Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 18d Gender: Male Location: Adelaide Posted 25/09/13 10:36 PM Share Posted 25/09/13 10:36 PM Do u have a fg mk 2 ? Link to comment Share on other sites More sharing options...
AzMahoony Hench, but no longer shredded or tanned. Member 3,343 Member For: 17y 22d Gender: Male Location: Canning Vale, W.A Posted 25/09/13 11:46 PM Share Posted 25/09/13 11:46 PM That late model mk1/mk2 feel.. Just CAREFULLLY BUT FIRMLY bend it untill you have enough clearance to fit it up. Wish I took pics of this when I did my install There's no other way around it unfortunately as the kits aren't version specific :/ Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 16y 4m 25d Gender: Male Location: Probably above atmospheric pressure Posted 26/09/13 05:05 AM Share Posted 26/09/13 05:05 AM Maybe shoulda bought Plazmaman instead of the less well known Palzmaman brand from the title :(...sorry couldn't help it. At least I waited until some useful replies were in 6 Link to comment Share on other sites More sharing options...
Doddo22 Member 135 Member For: 11y 1m 22d Gender: Male Location: Newcastle Posted 26/09/13 05:42 AM Share Posted 26/09/13 05:42 AM Maybe shoulda bought Plazmaman instead of the less well known Palzmaman brand from the title :(...sorry couldn't help it. At least I waited until some useful replies were in haha im just about to but a palzmaman in mine Link to comment Share on other sites More sharing options...
milk Member 6 Member For: 12y 10m 4d Posted 26/09/13 06:06 AM Author Share Posted 26/09/13 06:06 AM Yeah it's a late model mk1. Could I heat it with a heat gun or blow tourch to bend it or not?Its also rubbing on the little aluminium cube that's directly below the a/c pipe about 20cm but I can probably fix that by moving the radiator support back even more.Whats your clearance like between the thermos and the fanbelt/pullys?I probably should have opted for the Plazmaman instead yeah. Link to comment Share on other sites More sharing options...
AzMahoony Hench, but no longer shredded or tanned. Member 3,343 Member For: 17y 22d Gender: Male Location: Canning Vale, W.A Posted 26/09/13 06:32 AM Share Posted 26/09/13 06:32 AM I drilled into the brackets/supports and moved it all back about 5cm. Have about 2cm clearance, hardly any but enough without making it dangerous. I just used my muscles and kept on bendng it up and then back to sorta flatten it out like the early mk1's Link to comment Share on other sites More sharing options...
AzMahoony Hench, but no longer shredded or tanned. Member 3,343 Member For: 17y 22d Gender: Male Location: Canning Vale, W.A Posted 26/09/13 06:34 AM Share Posted 26/09/13 06:34 AM Should mention top brackets in engine bay and radiator supports under the car. Was annoying but it worked. Link to comment Share on other sites More sharing options...
milk Member 6 Member For: 12y 10m 4d Posted 26/09/13 06:38 AM Author Share Posted 26/09/13 06:38 AM I don't suppose you could get a picture? Probably covered with lots of plastic and the bumper though. Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 18d Gender: Male Location: Adelaide Posted 26/09/13 10:23 AM Share Posted 26/09/13 10:23 AM Plazmaman kits come with the new RHS support bolt n play spec Link to comment Share on other sites More sharing options...
