MurdoK Donating Members 719 Member For: 13y 10m 2d Gender: Male Location: Perth,WA Posted 08/09/13 09:35 AM Share Posted 08/09/13 09:35 AM Sooooo I own a 09 FG XR6 turbo and have done so for a bit over 3 years now.Didnt own it long before deciding to mod it and be happy to never speak to ford again.Fitted ID 1000s,Nizpro Cooler, Nizpro Exhaust and a tune.that netted 302rwkw's and felt very strong.(Green= stock,Pink=tune,cooler and injectors and Black= after exhaust fitted)Next was some Brembos(6 piston fronts,braided lines,DBA T3 and upgraded rear calipers).Took it to the strip and ran a best of 11.95 @117mph on some abused street tyres and was pretty happyOriginal plan was to enjoy the new power for a few months before upgrading turbo and the like.Well over 2 years later...and with a tune that needed some adjusting and a gearbox that wasnt at its peak anymore I decided to finish off what I started.New rims and tyres for more grip and some more go fast bits, GTX35 and a tuneSo 428@17psi on pump 98.List of mods: ID 1000 injectors,Nizpro Cooler, Nizpro Exhaust, GTX3582 with actuator and port work, growler to keep the stock crossover, Twin pump process west surge with kit to fit upto factory rail, Valve springs, XFT built stage 2 gearbox with input shaft and tailshaft upgrades. earls turbo oil line.after now spending some time driving the car and adjusting to a completely different drive,I love it. WOT runs changing gears is seemless and quick.Next will be some pump E85,ET streets and try to run a 10. oh and some fun at powercruise. 4 Link to comment Share on other sites More sharing options...
XtRmn8 570Nm @1800rpm Donating Members 2,441 Member For: 20y 7m 2d Gender: Male Location: Perth, WA Posted 08/09/13 09:46 AM Share Posted 08/09/13 09:46 AM Epic effort mate. That is some serious power!!What exhaust are you running? Looking at your 302.4kw dyno sheet the torque increase is epic after the exhaust was fitted (black line).Cheers Link to comment Share on other sites More sharing options...
MurdoK Donating Members 719 Member For: 13y 10m 2d Gender: Male Location: Perth,WA Posted 08/09/13 10:01 AM Author Share Posted 08/09/13 10:01 AM Thanks mate. Full Nizpro System 1 Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 28d Gender: Male Location: Perth Posted 08/09/13 10:22 AM Share Posted 08/09/13 10:22 AM (edited) Yep you cant say enough about the power of NIZPRO. Should see high 400s with E85.Did you change the camshafts. Is it a built motor. That RPM seems to high for stock motor and cams. Edited 08/09/13 10:25 AM by arronm 2 Link to comment Share on other sites More sharing options...
f6mark Member 2,908 Member For: 13y 2m 9d Gender: Male Posted 08/09/13 10:24 AM Share Posted 08/09/13 10:24 AM well done mate. got be happy with that. a lot tuners r making that power on e85 not 98. that's a awsome result. well done to simon at XFT. he is one of the best. 1 Link to comment Share on other sites More sharing options...
MurdoK Donating Members 719 Member For: 13y 10m 2d Gender: Male Location: Perth,WA Posted 08/09/13 10:46 AM Author Share Posted 08/09/13 10:46 AM stock cams and engine arron.only valve springs have been touched.cheers Marky. Simon sure does know how to get these things up and going 1 Link to comment Share on other sites More sharing options...
Hype Member 77 Member For: 10y 7m 22d Gender: Male Location: Canberra Posted 08/09/13 11:32 AM Share Posted 08/09/13 11:32 AM Definitely got to be happy with that! Link to comment Share on other sites More sharing options...
old_mate Member 767 Member For: 18y 2m 10d Gender: Male Location: Brisbane Posted 08/09/13 12:53 PM Share Posted 08/09/13 12:53 PM most I have seen on 98 for such low boost as well compared to what I typically seeany idea how much timing its running?epic result dude Link to comment Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 21y 24d Gender: Male Posted 09/09/13 01:38 AM Share Posted 09/09/13 01:38 AM That dyno graph is a pretty good comparison of the effect of upgrading to a larger turbo. The boost on the low end is softened quite a bit on the bigger turbo. Link to comment Share on other sites More sharing options...
AdamIan69 Bronze Donating Members 401 Member For: 11y 2d Gender: Male Location: WA Posted 09/09/13 02:16 AM Share Posted 09/09/13 02:16 AM Good power mate. I got the same setup as you without a built box and I have a dyno graph that reads 381wkw. Tunes by XFT 1 Link to comment Share on other sites More sharing options...
