Woznaldo Member 28 Member For: 10y 11m 17d Gender: Male Location: South West Sydney Posted 20/06/13 11:51 AM Share Posted 20/06/13 11:51 AM Evening All,I've done a bit of a search but have had trouble finding anything concrete on what level of VCT exists on the Barra Engine.I know that it's the infinitely variable type, but does work on both Intake and Exhaust Camshafts or just one?Also, I read a little about how it's all controlled but not how the PCM knows what position the Camshaft is in?Woz Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 18y 6m 30d Gender: Male Location: Perth Posted 20/06/13 01:33 PM Share Posted 20/06/13 01:33 PM Ba XR both cams advance/retard togetherBA Fpv Cams Advance/retard independentlyBF XR/FPV as per BA FPVFG XR/FPV as per BA FPV/BF,but FG FPV's also have duo-phased inlet cams (lobes are offset so one intake valve opens before the other for better offboost performance/fuel econ) I am unsure if this also applies ot FG xr'sAll engines have a Cam angle sensor for each cam at the back of the cyl head. Link to comment Share on other sites More sharing options...
Mr_4.0 Member 1,096 Member For: 13y 3m 3d Posted 20/06/13 02:00 PM Share Posted 20/06/13 02:00 PM I didn't think the independent timing came in until the bf ?? I thought all BA models advanced/retarded cams together. Yes the duo phased cams in FG are great. Allows more lift and duration for the same engine vacuum and creates swirl in the chamber for a cleaner burn. Link to comment Share on other sites More sharing options...
Mr_4.0 Member 1,096 Member For: 13y 3m 3d Posted 20/06/13 02:02 PM Share Posted 20/06/13 02:02 PM Also should add, pretty sure from base model NA to FPV typhoon, the FG cams are all identical. All got duo phased. Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 23d Gender: Male Location: Adelaide Posted 20/06/13 02:04 PM Share Posted 20/06/13 02:04 PM Its all about the swirl baby I believe 50degrees is the max rotation from the phasors Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 18y 6m 30d Gender: Male Location: Perth Posted 20/06/13 02:36 PM Share Posted 20/06/13 02:36 PM I'm 99% sure ba typhoons got independent valves timing, will hunt around to see if I can back this up. Link to comment Share on other sites More sharing options...
Woznaldo Member 28 Member For: 10y 11m 17d Gender: Male Location: South West Sydney Posted 20/06/13 09:27 PM Author Share Posted 20/06/13 09:27 PM Thanks for the responses Guys.What do the Cam Angle Sensors read? If it's some kind of toothed wheel, does anyone know the wheel pattern? Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 18y 6m 30d Gender: Male Location: Perth Posted 20/06/13 10:45 PM Share Posted 20/06/13 10:45 PM It's a toothed wheel. I have some cams in my workshop I can grab some photos when I get home tonight, if somebody doesn't post some sooner Link to comment Share on other sites More sharing options...
Woznaldo Member 28 Member For: 10y 11m 17d Gender: Male Location: South West Sydney Posted 21/06/13 06:08 AM Author Share Posted 21/06/13 06:08 AM Awesome, thanks Ralph. Link to comment Share on other sites More sharing options...
Ninka Donating Members 1,850 Member For: 21y 3m 30d Gender: Male Location: Perth, WA Posted 21/06/13 02:35 PM Share Posted 21/06/13 02:35 PM This may help if you look at top right of engine, you can see the cam sensor pickup 'gears'This is the first engine built for me by Xtreme in about 2005 Link to comment Share on other sites More sharing options...
