Anguz16 Member 3 Member For: 12y 21d Posted 19/06/13 01:13 PM Share Posted 19/06/13 01:13 PM Hey all,I own a 2010 FG XR6T, recently the battery died so I replaced it. Now my car wont start when I turn the ignition over nothing happens at all! The new battery is fine all fuses seem fine, I got a scan tool and ran it through the car, the car showed up with 20 fault codes after documenting each code we cleared them but 4 still remain.U1900P1000U1055U1066Can someone please help me or show me a solution! Link to comment Share on other sites More sharing options...
_Velocity_ Bronze Donating Members 2,768 Member For: 12y 11m 29d Gender: Male Location: Victoria Posted 19/06/13 01:28 PM Share Posted 19/06/13 01:28 PM (edited) P1000 Check of all OBDII Systems Not CompleteU1900 CAN Communication Bus FaultU1066 SCP (J1850) Invalid or Missing Data for Primary Id $42U1055 SCP (J1850) Invalid or Missing Data for Primary Id $37Can bus communication errors might be your issue. Hopefully someone with more of an idea here can chime in with an answer. I remember someone having an issue here before when changing the battery. There is a procedure to go through to fix any immobiliser issues. Edited 19/06/13 01:32 PM by _Velocity_ Link to comment Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 14y 3m 5d Gender: Male Location: Christchurch, New Zealand Posted 19/06/13 08:02 PM Share Posted 19/06/13 08:02 PM Almost like the ECU had a little fry up. Did you try charging, jump starting or anything while the old bad battery was in the car?It may not be ECU but replacing a battery is pretty easy and normally not an issue. Link to comment Share on other sites More sharing options...
Breeze_xr Bronze Donating Members 168 Member For: 12y 1m 17d Gender: Male Location: Newcastle Posted 19/06/13 10:12 PM Share Posted 19/06/13 10:12 PM My dad had an au series 3 futura and one day and when the battery died the ecu forgot all his keys and wouldn't start at all He got it towed to ford and knew exactly what had happened and fixed the ecu on the spot, they were certain that the low voltage from the old battery caused the problem Call up ford and see what they think Sent from my HTC EVO 3D X515m using Tapatalk 4 Beta Link to comment Share on other sites More sharing options...
Anguz16 Member 3 Member For: 12y 21d Posted 20/06/13 12:41 AM Author Share Posted 20/06/13 12:41 AM I tried jump starting the car with the old battery still inI live about 500kms from the closest ford dealer. im onto ford now as the car is still under new car warranty but its not really going anywhere whether they believe its a warranty or not job Link to comment Share on other sites More sharing options...
jas98 Member 1,029 Member For: 11y 9m Gender: Male Location: Maryborough Qld Posted 23/09/13 05:02 AM Share Posted 23/09/13 05:02 AM how did this turn out? Link to comment Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 21y 23d Gender: Male Posted 23/09/13 08:45 AM Share Posted 23/09/13 08:45 AM (edited) THere should be a rule.If you post up seeking advice from this forum, then at the very least you should have the manners to post up the solution to the problem sometime down the track (if we couldn't solve it). Edited 23/09/13 08:46 AM by turbotrana 1 Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 17y 10m 27d Gender: Male Location: @ my laptop Posted 23/09/13 09:46 AM Share Posted 23/09/13 09:46 AM yes exactly, or ban time Link to comment Share on other sites More sharing options...
stroller SHLAMBD. Member 259 Member For: 11y 11m 17d Gender: Male Location: Perth NOR Posted 23/09/13 12:20 PM Share Posted 23/09/13 12:20 PM just read through this. my car always has the p1000 on my xcal. doesnt go away when you try clear dtc's. whats it mean?cheers Link to comment Share on other sites More sharing options...
madmaz555 New Member 4 Member For: 4y 6m 6d Posted 17/10/19 12:13 AM Share Posted 17/10/19 12:13 AM im having same issue..can you please help me. Link to comment Share on other sites More sharing options...
