Aaron12257 Member 2 Member For: 11y 5m 28d Gender: Male Location: Canberra Posted 27/08/13 01:11 AM Author Share Posted 27/08/13 01:11 AM Hi guys, thought id let you know how I went. I ended up taking the TT to a mechanic that I have used before (Jax), I got the bushes replaced and two new tyres fitted all for under 1K. Deffinately pays to shop around.thanks for all your info. Link to comment Share on other sites More sharing options...
xX-Territory-Xx Member 58 Member For: 10y 2m 6d Gender: Male Location: Hunter Valley Posted 16/02/14 11:44 AM Share Posted 16/02/14 11:44 AM Bit of thread dig here, apologies in advance. I just bought a Territory recently and finally picked it up today, drove 9 hours home and notice vibration from the front end that starts from 60-110+kph.. Driving in a straight line and taking a slight right turn at speed is a constant vibration, come to a sweeping left turn and it disappears!! (Vibration is constant with road speed not engine rpm) Link to comment Share on other sites More sharing options...
xX-Territory-Xx Member 58 Member For: 10y 2m 6d Gender: Male Location: Hunter Valley Posted 19/02/14 11:46 PM Share Posted 19/02/14 11:46 PM Me again :D Can anyone tell where the fill point it for the front diff? Cheers Link to comment Share on other sites More sharing options...
fordfreak XRT07 Member 378 Member For: 15y 9m 10d Gender: Male Location: glenwood Posted 19/07/14 08:33 AM Share Posted 19/07/14 08:33 AM Just payed $1010 for genuine diif bushes + new rubber bushes for the front sway bar. inc labour. - my diff bushes were shot badly.dropped down the sub frame and power steering rack. , removed the intercooler for the cradle. Link to comment Share on other sites More sharing options...
bjc Donating Members 2,812 Member For: 20y 7m 16d Gender: Male Location: Townsville Posted 20/07/14 12:33 AM Share Posted 20/07/14 12:33 AM Did you do the third diff bush also (drivers side)? Mine is still standard but it may have had it also even though my dodgey photos I took seem to suggest it's ok but have hear it's a bastard of a job just for that bush...I had the two passenger side diff bushes replaced as they were rooted and bought the whiteline brand (black two piece each bush) as they were softer than the pedders brand but identical in fitting and make. Cost me $110 for the bushes and my mechanic charged me $350 for labour as I told him blokes can do it in the driveway in 3hrs!Also had my front diff breather break a while ago and there is only 2 inches left on the hose. It has spewed whatever oil it needed out and I checked it which it is low but still ok for now although the breather is impossible to get unless you have stick arms! Link to comment Share on other sites More sharing options...
peg Donating Members 3 Member For: 8y 28d Gender: Male Location: Tasmania Posted 22/03/16 09:23 AM Share Posted 22/03/16 09:23 AM Changed mine today -2 hours at the most , with a friend that has air tools and hoist - remove pass side tire and rotor - undo 3 bolts move diff over to driver side about 30 or 40 mm , cut out old shell and replace with new ( bit of mucking around ) replace everything - surprised us how quick we did it - should cost couple hundred - depends what they charge per hour 1 Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 18y 6m 27d Gender: Male Location: Perth Posted 22/03/16 01:35 PM Share Posted 22/03/16 01:35 PM -2 hours is pretty impressive. 3 Link to comment Share on other sites More sharing options...
peg Donating Members 3 Member For: 8y 28d Gender: Male Location: Tasmania Posted 23/03/16 07:43 AM Share Posted 23/03/16 07:43 AM Looks lot harder then it really is - machanic mate thought had to pull off lots of bits and pieces but we looked on Internet and seen it wasn't that hard so thought try it - he thought was going take 8/10 hours do it too - also thought gearbox was clunking when changing gears , turned out to be the bushes too so I am happy now lol 1 Link to comment Share on other sites More sharing options...
joblue New Member 4 Member For: 7y 6m 23d Posted 03/10/16 11:17 PM Share Posted 03/10/16 11:17 PM Did mine yesterday it's a messy job the bushes look like a war zone when you finally get them out. I threw my daughter's territory up on the hoist to havea llook and noted that they have already been done but whoever did it didn't orientate the bushes properly. Rears slots should be vertical front 45 degrees from vertical clockwise looking at it from the wheel bay. Cheers Link to comment Share on other sites More sharing options...
