NVT Formerly EGOBFXR6 Donating Members 1,111 Member For: 16y 2m 14d Gender: Male Location: Perth, WA Posted 07/05/13 02:12 PM Share Posted 07/05/13 02:12 PM Hello Gents,I'm hoping to change the coolant in my FG F6 this weekend. I've read through the forums and I understand the initial 'coolant' fill is some sort of 50/50 coolant/water.It's gone brown and crappy and the car runs a little hotter than it should.From what I read, apparently Techtaloy 90+ is a good choice but I don't know if it's the same for an FG as opposed to the B-series cars (Which the thread related to). What's the best coolant that I can get from repco or supercheap?I changed the coolant in my BA XR6T a few months ago and I'm assuming it's similar with the F series - Can anyone tell me if it's any different? Anything to note or look out for?From memory is it roughly - Add coolant flush and follow directions, wait for car to cool, drain with radiator plug, rinse through system when block is cold and run car with heater on for a minute or two, redrain then add new coolant, run car until fluid is pulled through system and top up accordingly.Thanks guys,Dan Link to comment Share on other sites More sharing options...
XRSEXT Member 235 Member For: 11y 8m 23d Gender: Male Posted 09/05/13 10:14 PM Share Posted 09/05/13 10:14 PM coolant is coolant.. just a 50/50 mix of your desired brand will do the trick Link to comment Share on other sites More sharing options...
unclewal Donating Members 583 Member For: 13y 6m 30d Posted 09/05/13 10:42 PM Share Posted 09/05/13 10:42 PM I ran radiator flush in mine for the required time as per the bottle (Nulon). Then flushed the system with a hose, ran it till the car was up to temp, flushed it pulling the radiator plug once it had cooled down, then refilled with 50/50 red nulon coolant, run the car with heater on flat out and made sure it was up to the max level in the reservoir, gave it a few revs to get rid of any air locks while the reservoir cap was off and filled it back up to the max level.Job done ! Link to comment Share on other sites More sharing options...
Bonjaz Donating Members 1,841 Member For: 15y 4m 12d Gender: Male Location: CQ Posted 10/05/13 12:14 AM Share Posted 10/05/13 12:14 AM yea pretty much as above. I flushed mine with a hose then refilled with supercheap green nulon premixed stuff. works well and kept its colour up until I sold it. Link to comment Share on other sites More sharing options...
NVT Formerly EGOBFXR6 Donating Members 1,111 Member For: 16y 2m 14d Gender: Male Location: Perth, WA Posted 10/05/13 01:51 AM Author Share Posted 10/05/13 01:51 AM Thanks Gents,I think I'll get this done on the weekend then.Cheers,Dan Link to comment Share on other sites More sharing options...
