cobra588 Inactive Members 1 Member For: 10y 11m 26d Posted 29/04/13 08:06 AM Share Posted 29/04/13 08:06 AM OK, I know similar questions have been asked but couldnt find any that were exactly the same as mine. I have a 2003 xr6t and recently the left side rear end has been making a clunking\knocking noise when going over bumps and rough roads. It doesnt seem to happen when both wheels hit a bump but rather when it is the left rear wheel by itself. I was wondering if anyone has had a similar thing happen and if there were any solutions to this problem. I have had the 3 diff mounts replaced less then 5000k ago. I have had a look at the bushes and the only ones I can see that look suspect is the top shock bushes. Should these fit flush in the center with the bolt that holds them in becuase there seems to be a 3mm gap between the bolt and the bush. Anything would be helpful. Also one more sympton is that sometimes when taking off from a standstill the rear end will shutter as if somthing is holding it back. Thanks Link to comment Share on other sites More sharing options...
perendale express Member 6 Member For: 12y 3m 15d Posted 30/04/13 07:39 PM Share Posted 30/04/13 07:39 PM Worn shock absorber? Link to comment Share on other sites More sharing options...
