fehlbie Donating Members 142 Member For: 15y 23d Posted 21/04/13 01:46 AM Share Posted 21/04/13 01:46 AM Need some help.I have just fitted an aftermarket upgraded tailshaft from sydney driveline services to my FG XR6 turbo.The original bolts that hold the tail shaft to the diff, that have the plastic weights could not be used as the uni joint is now too big for me to get the bolts in and the plastic weights.So I have used some socket head bolts instead.Now I get a bad vibration at 90km+ under acceleration and deceleration.Does the tail shaft now need dynamic balancing by Ford? Link to comment Share on other sites More sharing options...
Rootster Just a large member member Silver Donating Members 3,125 Member For: 15y 6m 8d Gender: Male Location: sydney Posted 21/04/13 03:11 AM Share Posted 21/04/13 03:11 AM So you also changed your pinion yoke ... Link to comment Share on other sites More sharing options...
jas98 Member 1,029 Member For: 11y 9m 1d Gender: Male Location: Maryborough Qld Posted 21/04/13 05:48 AM Share Posted 21/04/13 05:48 AM you say you went to a driveline place? ask them, maybe theres something you missed regarding balanceing etcalso is everything done up tight? etc Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 24d Gender: Male Location: Adelaide Posted 21/04/13 05:50 AM Share Posted 21/04/13 05:50 AM A few are finding it hard to get aftermarket shafts right when the pinion yoke set up is changed If u find an answer please post up !! 1 Link to comment Share on other sites More sharing options...
fehlbie Donating Members 142 Member For: 15y 23d Posted 21/04/13 10:45 PM Author Share Posted 21/04/13 10:45 PM Yeah the pinion yoke was changed to a 1350 uni and a flange. I will call my driveline guys and find out what I need to do. Link to comment Share on other sites More sharing options...
bionicxr6t05 Bronze Donating Members 2,216 Member For: 12y 8m 28d Gender: Male Posted 22/04/13 08:39 AM Share Posted 22/04/13 08:39 AM Ford cant balance it I youve changed the pinion flangeOne thing you could try... Seeing as the flange is new I assume its pretty smooth? Your local dealer could try using alloy wheel stick on weights on the outer surface of the flange at the points indicated during the balance procedure... Providing it doesnt need crazy amounts of weights and the weights stick ok it could work... Could also turn the tailshaft one bolt over on the flange until the closest balance point is reached requiring the least weights possible, will be time consuming but could work well... Link to comment Share on other sites More sharing options...
sexual harrassment panda I see a red door and I want to paint it black Donating Members 5,919 Member For: 14y 5m 29d Gender: Male Location: Far north queensland Posted 22/04/13 09:20 AM Share Posted 22/04/13 09:20 AM +1 for dynamic balance and stick on weights. Link to comment Share on other sites More sharing options...
ScatterBrain Donating Members 316 Member For: 14y 10m 22d Gender: Male Location: Brisbane Posted 22/04/13 10:38 AM Share Posted 22/04/13 10:38 AM just out of curiosity is it auto or manual? I've heard the vibration problem stems from the center bearing being to rigid. Link to comment Share on other sites More sharing options...
Benny Member 1,869 Member For: 20y 8m 18d Gender: Male Location: Newcastle Posted 22/04/13 11:46 AM Share Posted 22/04/13 11:46 AM Have you upgraded your centre bearing? If so have you made sure the centre height is the same as the oem bearing?Benny. Link to comment Share on other sites More sharing options...
xhxrsix Member 174 Member For: 17y 5m 17d Gender: Male Location: Melbourne Posted 22/04/13 02:02 PM Share Posted 22/04/13 02:02 PM I'd say stick on weights would fly off as soon as you gave it some stick... Link to comment Share on other sites More sharing options...
