Troubador1966 Member 4 Member For: 11y 2d Gender: Male Location: Newcastle Posted 15/04/13 12:52 PM Share Posted 15/04/13 12:52 PM Can anyone help out please, my beloved Xr6t is not starting? It did this a couple of weeks ago and I had to leave it overnight at a local servo. Went back late the next day and it started, also last week only this time I persisted by jiggling ignition and pushing auto shift from neutral to park. It took about 10 minutes or so before luckily started. I read a post regarding F6 button not starting and wonder if this is the starter motor??Fortunately it's in my drive this time! Link to comment Share on other sites More sharing options...
needfordspeed Member 166 Member For: 21y 3m 26d Gender: Male Location: Melbourne Posted 15/04/13 01:38 PM Share Posted 15/04/13 01:38 PM If its a 4 speed btr it may be your inhibitor switch. Link to comment Share on other sites More sharing options...
Troubador1966 Member 4 Member For: 11y 2d Gender: Male Location: Newcastle Posted 15/04/13 02:02 PM Author Share Posted 15/04/13 02:02 PM Thanks for reply, it's the 6 speed sequential Link to comment Share on other sites More sharing options...
boost69 Donating Members 737 Member For: 18y 10m 30d Posted 16/04/13 12:35 AM Share Posted 16/04/13 12:35 AM Not saying its relavent, but I would still double check your battery, and battery contact areas.If your alternator is not charging your battery, then your new battery will lose charge very quickly while you drive.You possibly might get an hours drive out of it, before things start playing up.Though if the voltage does decrease as you drive, you will notice other tell tale signs, such as your radio swtiching off, you will also notice your ZF will stop shifting gears.Its at that point time the cars just stalls... Link to comment Share on other sites More sharing options...
RowdyBurns Donating Members 641 Member For: 16y 1m 10d Gender: Male Location: Brisbane Posted 16/04/13 02:11 AM Share Posted 16/04/13 02:11 AM Does it turn over and not fire? Or is there just nothing at all? Link to comment Share on other sites More sharing options...
Mr_4.0 Member 1,096 Member For: 13y 2m 30d Posted 16/04/13 02:26 AM Share Posted 16/04/13 02:26 AM Yeah need more details about what it actually does it doesn't do when you try and start it But first post suggests possible inhibitor switch of sorts. Link to comment Share on other sites More sharing options...
Troubador1966 Member 4 Member For: 11y 2d Gender: Male Location: Newcastle Posted 16/04/13 02:46 AM Author Share Posted 16/04/13 02:46 AM Thanks guys, I have checked the battery connections again, there is nothing at all (not turning over) all instrument lights and command centre appear and I haven't had any trouble with radio turning off or engine cutting off whilst driving recently. I also haven't noticed any of the warning lights being on whilst driving! It gives the normal click when key turned but no turn over?? I have to confess I know zero mechanically but love these cars! I'm thinking I need to get someone to look at it. I was hoping there was an easy fix and thought maybe this could be a common problem? Link to comment Share on other sites More sharing options...
RowdyBurns Donating Members 641 Member For: 16y 1m 10d Gender: Male Location: Brisbane Posted 16/04/13 02:50 AM Share Posted 16/04/13 02:50 AM I had a similar problem in my BF. Random starting issues, usually when it was hot. It was the the starter motor, it finally died, replaced it, never had another issue. Link to comment Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 14y 3m Gender: Male Location: Christchurch, New Zealand Posted 16/04/13 03:42 AM Share Posted 16/04/13 03:42 AM What about other earth connections, connections at the starter for being tight. Not just the terminals on the battery. Link to comment Share on other sites More sharing options...
bionicxr6t05 Bronze Donating Members 2,216 Member For: 12y 8m 22d Gender: Male Posted 16/04/13 08:08 AM Share Posted 16/04/13 08:08 AM Starter motor 1 Link to comment Share on other sites More sharing options...
