Seany Member 8 Member For: 11y 8d Gender: Male Location: Perth WA Posted 23/03/13 07:24 AM Share Posted 23/03/13 07:24 AM gday guys I have a 2004 ba xr6t and today when I had a lookg under the car I noticed that that bellhousing has abit of trans oil around it, can anyone shed some light on what it could be and if its a common problem with the ba's? Link to comment Share on other sites More sharing options...
Benny Member 1,869 Member For: 20y 7m 22d Gender: Male Location: Newcastle Posted 23/03/13 09:29 PM Share Posted 23/03/13 09:29 PM Is it dripping off the bottom of the bell housing or just on outside of it? Are you 100% sure it's trans fluid? Benny. Link to comment Share on other sites More sharing options...
xr606 New Member 9 Member For: 12y 9m 11d Posted 24/03/13 12:07 AM Share Posted 24/03/13 12:07 AM If trans fluid, front pump leaks are common on the BTR 4spIf not trans fluid could be a rear main sealJust my 2 cents Link to comment Share on other sites More sharing options...
Benny Member 1,869 Member For: 20y 7m 22d Gender: Male Location: Newcastle Posted 24/03/13 09:58 AM Share Posted 24/03/13 09:58 AM ^^^^ Agree. As long as it's not being blown back from further forward on the engine then it will be gearbox out to find the source. Link to comment Share on other sites More sharing options...
Seany Member 8 Member For: 11y 8d Gender: Male Location: Perth WA Posted 24/03/13 10:38 AM Author Share Posted 24/03/13 10:38 AM yeah definatly trans fluid, and yeah its dripping off the bottom of the bellhousing, thanks alot for the help guys gna get it looked at sometime this week gna get diff bushes done while im at it Link to comment Share on other sites More sharing options...
Benny Member 1,869 Member For: 20y 7m 22d Gender: Male Location: Newcastle Posted 24/03/13 09:02 PM Share Posted 24/03/13 09:02 PM (edited) Has your rear main been replaced before? While the box is out you could change that also considering the box will be out. Cheap part and easy to replace. How much power is your car making? Do you have a transcooler fitted, is your BTR built or stock?Benny. Edited 24/03/13 09:03 PM by Benny Link to comment Share on other sites More sharing options...
