JETURBO
Jet's Tuning (Oh No)
I looked at the single post but found they (imo) restrict to much space under the car due to the bulky arms having to reach across and support the other side of the car.
Great idea though and being a trolley jack essentially means placement is infinite...
Haha I didn't even know they existed! I was just being stupid.
Share this post
Link to post
Had Martin give me a call due to some “Hectic” noises coming from his FGX G6ET and without “to much” interrogation I managed to pin point beyond a doubt what it was and sure enough the flex plate had come loose. Bit devastated as he had been to another workshop previously to have a Pitlane Performance HD flex plate installed with ARP bolts, unfortunately the best parts can’t work correctly with less than correct installation methods in place !
To say he was beyond annoyed and zero chance of returning to said workshop I agreed to tackle the job but on only my way or the Flintstones highway as I’m not into doing things twice ! Nothing wrong with the Pitlane flex plates but I knew it would be “beaten” up after coming loose so it was onto Brad from Atomic for the best of the best with his full HD billet kit ;)
Whilst the ZF was coming out it was time to hit it up with a major Flush, new filter and gasket and fill with good mate Gulf Western SYN TS oil. Spent time re dressing all mating surfaces and blind threads ready for the new gear and a correct installation !
All said and done Martin is one happy camper again
Edited by JETURBO
Share this post
Link to post
I wonder why Atomic use a plated bolt for the flexplate
That atomic flexplate is really nice.
Edited by arronm
Share this post
Link to post
it's bad when you pay someone to do a job and they can't follow simple instructions, a little bit of Loctite could have saved him some money
Share this post
Link to post
Mick if they didn’t use loctite the chances of them using a correct torque sequence and a torque wrench would be minimal one would think ..... 🤔
x3 Dugger Dugger’s on the rattle gun please 🙃
Share this post
Link to post
^ yeah the whole “oh the stud was broken when we took the nut off”
yeah righto farkwit, and no, you’re not charging me for new wheel studs! 🤣
Edited by MBAF
Share this post
Link to post
Had Rich back in for the next round of mods and this was a long time coming as he’s been very happy with the first round of mods for quite some time. Eventually it gets everyone though as power is addictive !
Out with the factory intercooler and in with a Plazmaman 800hp Polished core, new silicone joiners to suit his already fitted alloy pipe kit
Out with the factory cat back exhaust and in with a X-Force 409 SS un polished cat back system in 3.5*
Major service
Major cooling system service
Differential service
Re tune on 98 fuel
Finished up at a comfortable 321rwkw @ 15 psi flat
Goes really well and smokes the Nitto Invos hard in the first three gears ;)
My Office
Share this post
Link to post
Had a new face in with Chris recently purchasing this BA turbo that had a short list of mods and accessories but he wanted me to check the car over, knock out a service and then check it on the Dyno with some data logging and a general opinion of the current tune performed by a company that’s located in SA’s mid north.
Now this is what came out and obviously far from optimal for the weakest of all turbo engines but for the people with not so great eyes yes that’s 17psi on the hit
on the up side the fuel was somewhat controlled but the fact the intercooler was a Ebay ( Wog cooler ) and IAT’s cracked 80*c by 6250rpm and over 12* of advanced timing the knock box was having a red hot spazz and getting way to excited for what should be delivered. All said and done there’s room for instant improvement even on the current list of mods !
Share this post
Link to post
Had Mark @Boosted Blu in for a set of Brembo 6 pot fronts and 4 pot rears with Series T3 5000’s up front and T3 4000’s on the rear Then some “Brake-safe” braided lines all round
Why ?
Well he had to fill the massive wheels that he’s just got on the ute and what better way to go about it than some stealth black units with the white decals. Still even though the Brembo 4 pot rears are big But nothing looks big with 11.5* x 20* Ferrada FR2 rims wrapped in 305/30 Michelin Pilot sport 4’s and all snuggled down on the Shockworks shocks and King spring HD SSL leafs With the MalWood Automotive Anti tramp control bars I installed last year
Amazing, yeh it looks killer and what a excellent way to tie together not only the 500rwkw it makes but with stance, looks and now big stopping power to pull it all up, Have to hand it to Mark for piecing together a great combo and I’m stoked to have been the one to build this ute from stock to what it is now :)
Share this post
Link to post
that's a beautiful setup... tell him to come back on here and make his own build thread if he's willing to splash like that on suspension/wheels/tyres :)
Share this post
Link to post
Must be 6-4 Brembo month as good mate @FormulaFG has decided to have his beautifully otherwise standard Mk2 FG XR6T “Modified” ( except wheels and one of my ZF transmission cooler kits ) with only 40,000kms on the clock it was nice to do such a great modification before the power comes into play :)
Leigh has opted to run with RBS spec braided lines vs factory rubber Brembo lines and go to the DBA street spec pads on my recommendation over the factory Brembo pads... to renew one spec in the mix was brand new factory Brake bolts instead of re using the factory bolts which is not a bad option at all ;)
Fitted up and bedded in the difference is very noticeable and what an amazing bit of kit and should cope with anything Leigh will throw at them. DBA4000’s and DBA pads with 20 pistons pushing does wonders for confidence in pulling up near on 2 Tonnes
Edited by JETURBO
Share this post
Link to post
If you go that far may as well fit 5000s. Awesome package... Black looks awesome. If I bought new it would be black.
Share this post
Link to post
Once again I couldn't be happier with the work the Aaron has done to my vehicle. He treats my car with the same care and attention that he would if it was his own car.
DBA 5000s would have been nice, arron, but to be honest this setup is already way more than I'll ever need and I couldn't justify the extra couple of bucks. I would have been happy with a Brembo 4/PBR combo, which I had ready to go, but at just as I was about to have Aaron fit them the Brembo 6/4 setup came up and I just couldn't say no to that.
Black for the win 100%. I'm loving the subtle stealth look they have about them.
Share this post
Link to post
Thanks for the kind words Leigh ☺️
Always a pleasure working on a such well looked after FG mk2 Turbo
Share this post
Link to post
    No registered users viewing this page.
