k31th less WHY; more WOT Site Developer 28,300 Member For: 16y 13d Gender: Male Location: Melbourne Posted 24/09/19 07:33 AM Share Posted 24/09/19 07:33 AM tailshaft and engine/trans mounts I would guess, but you've already fixed up those... sorry, can't think of anything off the top of my head for a ute that would be at the rear and cause that... Link to comment Share on other sites More sharing options...
OZYWALKER XR50T Gold Donating Members 2,795 Member For: 10y 11m 22d Gender: Male Location: Western Sydney Posted 24/09/19 08:27 AM Share Posted 24/09/19 08:27 AM I've just got a new one for it but still ahve vibrations under acceleration/load. Any suggestions? *Feels* like it's coming from the rear. Either hard acceleration or foot+brake it starts up. Cruising at 100, nadda.This is common with aftermarket tail shafts. Well it was a few years back.Generally the uni joints vibrate more than the CV joint on the factory shaft. The new shaft you have also does not have the factory doughnut damper/bush so it will transfer more noise and vibration.Depending on the height of the ute you may have to add some spacers to lower the center bearing and align the shaft to have less angle between the uni joints. 2 Link to comment Share on other sites More sharing options...
4321 Bronze Donating Members 257 Member For: 10y 27d Posted 24/09/19 11:08 AM Share Posted 24/09/19 11:08 AM With my gibson shaft chasing same vibrations, new engine & gearbox mounts, spacers under the centre bearing, replacing diff bush's, back to gibsons, took it to hardy spicer and it turned out to be 'bent' Another $400 to them but at least it's fixed (%90 because of IMS hat) 2 Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 27d Gender: Male Location: Perth Posted 24/09/19 01:44 PM Share Posted 24/09/19 01:44 PM 7 hours ago, Trent0 said: Last week I ordered a new tail shaft from GJ Drivelines. It's a Pro Series - $1890 for anyone curious. Super simple to fit up - really nice looking bit of gear. After fitting, it felt good to drive around. I noticed under acceleration for 50+ I'd get some not so great vibrations. I'd noticed lately that jamming it in lower gears the gear stick would move a considerable amount (with engine torque). Turns out my gearbox mounts were shagged. I was able to replace them for $50 and only took me 20mins to do! Thinking this solved my issues, I took another test drive. No luck. I'd noticed a clunk developed in the front end over the past week as well after driving on some rough roads the weekend prior, I put it down to a flogged out bush. After having a hunch and checking the engine mounts, I'd discovered I had a missing mount nut 😕 Still trying to source something that fits. Look at the aluminum shavings in the engine mount stud threads, that's how far the engine has been "lifting". 1 Link to comment Share on other sites More sharing options...
camo86T Silver Donating Members 1,810 Member For: 10y 2m 11d Gender: Male Location: SW Sydney Posted 24/09/19 06:40 PM Share Posted 24/09/19 06:40 PM 10 hours ago, OZYWALKER said: This is common with aftermarket tail shafts. Well it was a few years back. Generally the uni joints vibrate more than the CV joint on the factory shaft. The new shaft you have also does not have the factory doughnut damper/bush so it will transfer more noise and vibration. Depending on the height of the ute you may have to add some spacers to lower the center bearing and align the shaft to have less angle between the uni joints. Same here, also had to stuff around a bit with spacers height. Have never changed since dropping SL leaves in a few years back, one of the things to do before it comes off the hoist sometime during the next 7 days hopefully... 1 Link to comment Share on other sites More sharing options...
Trent0 The Toxic Rocket Donating Members 574 Member For: 13y 11m 29d Gender: Male Location: Brisbane Posted 25/09/19 04:35 AM Author Share Posted 25/09/19 04:35 AM I've had a set of king SSL's? the lowest kings leafs, in the rear for the past 5 years. I'm still using the factory spacers (10mm?). Not sure whether or not to stuff around with different sizes or just drop it off at a diff shop to get looked at and sorted? Link to comment Share on other sites More sharing options...
camo86T Silver Donating Members 1,810 Member For: 10y 2m 11d Gender: Male Location: SW Sydney Posted 25/09/19 08:47 AM Share Posted 25/09/19 08:47 AM Sorry I meant SSLs also... Depends on the housing, one of my utes has a Gibson shaft, the other has a GJ drivelines unit - these particular shafts in any case have totally different bearing carriers Will throw up some pics in a bit if I can. As far as I knew you aim for the centre bearing to be slightly higher than what it would be if the whole shaft was dead straight from gearbox to diff. A) allows for a bit of diff pinion rise under hard throttle and B) apparently unis shouldn't run dead straight...pretty sure I read that on here years ago TBH - courtesy of @Ralph Wiggum possibly? 1 Link to comment Share on other sites More sharing options...
camo86T Silver Donating Members 1,810 Member For: 10y 2m 11d Gender: Male Location: SW Sydney Posted 25/09/19 09:10 AM Share Posted 25/09/19 09:10 AM Gibson shaft, with pissy little retainer plate - will fab a replacement for it. Needed 40mm spacers on this at stock height to get it right as the carrier tabs are right at the base. GJ shaft, totally different carrier 1 Link to comment Share on other sites More sharing options...
Trent0 The Toxic Rocket Donating Members 574 Member For: 13y 11m 29d Gender: Male Location: Brisbane Posted 02/10/19 02:24 AM Author Share Posted 02/10/19 02:24 AM On another topic - does anyone have recommendations for a steering/suspension shop in Melbourne? So much knocking and banging, I'd say a few bushes need replacing. Link to comment Share on other sites More sharing options...
Trent0 The Toxic Rocket Donating Members 574 Member For: 13y 11m 29d Gender: Male Location: Brisbane Posted 09/10/19 09:59 AM Author Share Posted 09/10/19 09:59 AM So I bit the bullet and took the ute in to a nice little workshop to get some noises in the front end checked. Nice little list of jobs to do Old mate said I'd be best off buying new Upper & Lower control arms with bushes & ball joints fitted as a replacement, less time and money to do. The harder part is finding parts online with genuine ball joints and bushes. Does anyone have recommendations for a seller? Link to comment Share on other sites More sharing options...
