  • Member For: 13y 8m 5d
Hey guys. Having a bit of difficulty selecting 2nd gear first thing in the morning when it's cold. Have only noticed it over the last month and just wanted to know if it would be considered "normal" for these gearboxes. It's only second gear, and if I try and force it in, it will grind like the clutch isn't in far enough. It only happens when the gearbox is cold and only second gear.
  • Member For: 15y 4d
Do you warm you car in the morning for 5 mins?
I noticed when I drive our manual turbo in this weather the whole shifter is cold as and have had the same problem.
Try warming it up I noticed when warming it up it eliminates this.
Normal maybe but it has been cold, freezing touching the gear knob.
  • Bronze Donating Members
  • Member For: 13y 4m 22d
Yeah id just wake up 10 min earlier and warm the car up before you head off for the day. Happened to me in my old R33 nearly every day in winter when I wanted to put it in reverse to back it up out of the garage.
  • Banned
  • Member For: 13y 8m 6d
its because the gear oil is thicker in the cold and it cant get forced out the little groves in the synchro ring, therefor the synchro doesnt grab the gear and match the speed to the main shaft.
is it going from 1-2 or 3-2? (just out of interest)
just put it in the 2nd gate and pull back gently, which will give the thick oil a better chance to dissapate.
dont know anything about the manual boxes, is there a thiner gear oil that can be used in them? I think its dex111 innit?
cheers, andy
  • Member For: 14y 11m 29d
  • Gender: Not Telling
I think this is a fairly common problem with any Tremec box. But don't force it into gear where its crunching. I generally throttle off and wait for it to drop into second when its ready. I live in Queensland were temps don't get down anywhere near the Southern States. Its like it knows its winter, maybe there is some inbuilt fuzzy logic. Cheers
cheers, andy
After speaking to Mal Wood I put the Penrite Syn (70W75) oil in, but he recomends Transmax Z. He did say not to put anything thick in it as it will damage ring gears. But I'm talking about T56, the stronger TR6060 ( which incidenty, I was told is the old T56 magnum) I'm not sure about. Cheers
  • Member For: 16y 7m 27d
Resistance into second is normal on the 6060. happens to me in the mornings. Just hold the shifter down (don't force) and it should find its place. I sometimes get little crunches here an there on freezing mornings. Doesn't even let me get into 1st at all in the cold unless im at a complete stop.
Edited by Paulie2256
I have to say this week has been more obvious cause it has been freezing in Southern States of Australia.
^^^^ Like Paul said.
  • Banned
yeah I got a zf and know nothing about t56 or tr6060 (infact this is the first ivheard of a tr6060 lol) all I know is the lighter the oil the easyer the changes will be. 70/75 is pretty light for a gear oil, there normaly 75/90+.
cheers, andy
