tofski Member 25 Member For: 11y 11m 21d Posted 03/05/12 11:07 AM Share Posted 03/05/12 11:07 AM Just got a bf zr6t mk 2 its go usual mods exhaust cooler and seimens injectorsHave done 200kms in it so far and its developed a tapping noise Only on idle and not at higher rpm , performes well and runs smooth ,noise increases when A/c compressor kicks in , the fella I got it off reckons that's it is injectors Noise and it is imminent ( sometimes does it and goes away) I'm thinking it might be timing chain , any input woud be appreciated Link to comment Share on other sites More sharing options...
gsd112 Donating Members 604 Member For: 13y 6m 23d Gender: Male Location: Penrith Posted 03/05/12 11:41 AM Share Posted 03/05/12 11:41 AM My old ba had a ticking noise at idle and it would come and go but only when warm. Turned out to be idler pulley. Link to comment Share on other sites More sharing options...
daztbo FLY-FPV Donating Members 474 Member For: 14y 8m Gender: Male Location: Greensborough Vic Posted 03/05/12 11:49 AM Share Posted 03/05/12 11:49 AM My ba has a noisy" chat chat chat chat" noise on cold start but goes away I'm thinking it's a lifter ??? Link to comment Share on other sites More sharing options...
bionicxr6t05 Bronze Donating Members 2,216 Member For: 12y 8m 1d Gender: Male Posted 03/05/12 08:45 PM Share Posted 03/05/12 08:45 PM Make sure the canister purge valve isnt hitting the lh strut tower Link to comment Share on other sites More sharing options...
riptide Member 733 Member For: 13y 2m 10d Gender: Male Location: Auckland, New Zealand Posted 03/05/12 09:46 PM Share Posted 03/05/12 09:46 PM (edited) Could be just about anything. Have you tried listening to it with a screw driver? I had a few different noises when I had a loose flex plate and a bent rod. Both only on idle.If you've over revved it flex plate and if it's over boosted or seemingly lost power on hard boost it may have detonated a little and bent a rod or two.Could be anything though.Injector noise doesn't go away. Edited 03/05/12 09:47 PM by riptide Link to comment Share on other sites More sharing options...
tofski Member 25 Member For: 11y 11m 21d Posted 03/05/12 11:32 PM Author Share Posted 03/05/12 11:32 PM It's conning from the top ,I think it may be the lifters ,it only does it when the motor warms up,I'm going to try some thicker oil the oil in it was put in by previous owner so I don't know what it even is , what oil would be best to use ? Any recomindations woud be helpful. Link to comment Share on other sites More sharing options...
Paulie2256 Donating Members 7,441 Member For: 15y 4m 6d Gender: Male Location: SE Melbourne Posted 03/05/12 11:49 PM Share Posted 03/05/12 11:49 PM Try castrol edge 10-60 1 Link to comment Share on other sites More sharing options...
gsd112 Donating Members 604 Member For: 13y 6m 23d Gender: Male Location: Penrith Posted 04/05/12 12:04 AM Share Posted 04/05/12 12:04 AM Mate mine sounded like it was definitley coming from the rocker cover but it was the idler pulley.Royal Purple 10-40. Link to comment Share on other sites More sharing options...
riptide Member 733 Member For: 13y 2m 10d Gender: Male Location: Auckland, New Zealand Posted 04/05/12 05:04 AM Share Posted 04/05/12 05:04 AM (edited) I use a full synthetic Total Oil 9,000 10/50.I thought the lifters were good in these. I've never had lifters make a noise in the 3 motors I've had in my BF.Don't just put any old thicker oil in. Think of the turbo. Do some research in the oil section. I would have done an oil and filter change when I bought it. Edited 04/05/12 05:06 AM by riptide Link to comment Share on other sites More sharing options...
xr6t_ute Donating Members 2,281 Member For: 16y 9m 3d Gender: Male Location: south east suburbs Posted 04/05/12 05:11 AM Share Posted 04/05/12 05:11 AM Yeh try changing the oil first. Link to comment Share on other sites More sharing options...
