Joey Thorne Donating Members 33 Member For: 12y 3m 12d Posted 28/03/12 02:35 AM Share Posted 28/03/12 02:35 AM hey guys so in my normal style I started off doing somthing I knew nothing about! its all apart of my style what I was doing was removing the icc so I could install some gauges I just jumped straight into it didnt bother to disconnect the battery rookie mistake! any how, half way thru the alarm starting going off and I figured it was time to disconnect the battery so I did, I finshed what I had to do and now when it came to starting my car it wouldnt start at all , I would turn the key to acc n all the lights were on but wouldnt start, the raido read "code error", and from what I have read it just takes half an hour or so to go back to normal as it is the origanal unit so no code is needed, but my issue now is the car wont do anything at all it dead nothing happens when the key is any position , Im thinking its prob fuses or relays, I relize I will have to take it some where but is there any trouble shooting tips you guys have befor I get it towed, just to make you all laught the sun roof is open n garage is full! im off to k-mart to by a garden shade haha... any help would be great! Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 18y 6m 28d Gender: Male Location: Perth Posted 28/03/12 03:07 AM Share Posted 28/03/12 03:07 AM The ICC isnt seated correctly in the connector behind it. Link to comment Share on other sites More sharing options...
Joey Thorne Donating Members 33 Member For: 12y 3m 12d Posted 28/03/12 03:10 AM Author Share Posted 28/03/12 03:10 AM Awsome that seems alot better ! Does it only plug into the white pin connector n the aerial jack? Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 18y 6m 28d Gender: Male Location: Perth Posted 28/03/12 03:14 AM Share Posted 28/03/12 03:14 AM B series? There's 4 connectors under the pcm (above the tissue box holder) that are for the BEM and the main ICC connector behind the ICC (the big white plug) The ICC connector will pull forward slightly and click into place. This reseats it so when the ICC is reinstalled the connector locks in correctly. Link to comment Share on other sites More sharing options...
nathen ride the lightning Donating Members 338 Member For: 17y 6m 9d Gender: Male Location: sydney Posted 09/04/12 10:11 AM Share Posted 09/04/12 10:11 AM how did you go? Link to comment Share on other sites More sharing options...
