Sydneyxr6t Member 63 Member For: 12y 5m 23d Gender: Male Location: Sydney Posted 23/02/12 05:51 AM Share Posted 23/02/12 05:51 AM (edited) GuysI am taking my FG XR6T in for a PWR stepped intercooler and retune next week, the car was modded a few months ago with:Growler CAIHigh flow catID 1000'sHerrod piping kitX3 and custom tunecar made 295rwkw and 750Nm of torqueMy question is my tuner has advised with the adding of the I/C I can run a little more boost on the turboWhat psi recommendations do you have for cars running similar mods?I was going to ask my tuner to run a high boost tune (16psi) and a safer 14psi tuneAny suggestions?I am not going down the road of ported wastegate/actuator etc, exhaust is standard except for high flow cat.The car looks dead standard, and I want to keep it looking and sounding that way:)E85 maybe an option as I have nice injectors, but I am suspecting I would need to upgrade the fuel pump.cheersArmando Edited 23/02/12 05:54 AM by Sydneyxr6t Link to comment Share on other sites More sharing options...
MexicanBatman G666E Turbo!!! Member 1,008 Member For: 14y 3m 8d Gender: Male Posted 23/02/12 06:04 AM Share Posted 23/02/12 06:04 AM Depends where you go, my car has basically same mods and made 311rwkw on 14psi that tapered off to 11psiAlso ran 11.6 1/4 with stock intake and bit less power...Some tuners up there will have you running 22psi boost, but I doubt it'll be any quicker... Don't bother with a safer tune, you'll never run it, why not do a ZF tune, this will help with times at the drags if your into that. Link to comment Share on other sites More sharing options...
Sydneyxr6t Member 63 Member For: 12y 5m 23d Gender: Male Location: Sydney Posted 23/02/12 06:44 AM Author Share Posted 23/02/12 06:44 AM T :sungum: hanks BatmanI already have the ZF tune and I am very happySo I should just go with a high performance tune?I wouldnt expect my tuner to run more than 18 psi on the little turbo, I think the current perfomance tune is 14-15psiCurrently I have loaded a performance tune/low boost tune(7psi) and valet tune (3000rpm limiter)cheersArmando Link to comment Share on other sites More sharing options...
TomT Spooling Member Donating Members 961 Member For: 12y 4m 18d Gender: Male Location: Blue Mountains, NSW Posted 23/02/12 06:49 AM Share Posted 23/02/12 06:49 AM I run 15 PSI on 98 with:Plazmaman IntercoolerPlazmaman PipingBattery RelocationPlazmaman hot side Air BoxInjectorsSurge Tank + Bosch 044 PumpHigh Flow Cat4" Dump pipe Link to comment Share on other sites More sharing options...
absmith New Member 18 Member For: 16y 9d Posted 07/03/12 08:04 AM Share Posted 07/03/12 08:04 AM For everyone out there here is how I went with my PWR cooler,I am running a PWR stepped intercooler on an FGXR6T Manual. I have the F6 turbo fitted, siemens 60LB, 12psi actuator, 4'' dump to 3 1/2'' exhaust, 5'' 100CPI cat, surge tank, Herrod piping kit, ported waste gate, running around 16psi boost. The PWR intercooler has been fine, we made 344.8rwkw on a 23degree day.Mine made 297rwkw with the standard turbo, stepped intercooler, 5'' cat, no surge tank and standard exhaust but all other mods listed were done at the time. The larger turbo makes a huge difference to the FG's, with the stock turbo the car would nose over at about 4000 RPM so I would find myself shifting early to keep it in the 2500-4000band. Now with the F6 turbo the car pulls really hard all the way to redline. I cannot stress the difference enough, it is like night and day.Thanks to C+V for the tuning work.Hope this helps, when I was researching the PWR cooler there was very little information out there. ipb.global.registerReputation( 'rep_post_1207043', { domLikeStripId: 'like_post_1207043', app: 'forums', type: 'pid', typeid: '1207043' }, parseInt('0') ); Link to comment Share on other sites More sharing options...
