zzz-ba ute Member 69 Member For: 14y 7m 21d Gender: Not Telling Posted 10/02/12 08:01 PM Share Posted 10/02/12 08:01 PM all right guys I have a 1978 CL valiant ute low comp 245, auto. This was in my BA ute, now in a shedXr6t engine with loom BTR 4speedBA pcm all ready tuned ------------- this is a BA NA ute pcm that had all security disabled and a xr6t tune put onSCT3 flash tuner matched to pcmIntercooler and pipingboost gauge manual boost controllerOBD2 port with approx 3" wiring (it was cut out of the car)The two body side ports for the engine loom and pcm loom. Again with small amount of wireThings I'm pretty sure I'll need BA accelerator pedal (with module)The wiring loom to make my bits connect??????????????????????????????Alright this is where the gurus step in and tell me what else. Link to comment Share on other sites More sharing options...
zzz-ba ute Member 69 Member For: 14y 7m 21d Gender: Not Telling Posted 12/02/12 07:07 AM Author Share Posted 12/02/12 07:07 AM Just like to clear up I am not looking for someone who has done the same thing, just anyone who knowswhat I would need to put it in a car that has no comps,ecu's bem's or bugger all harness of its own to splice to Link to comment Share on other sites More sharing options...
MexicanBatman G666E Turbo!!! Member 1,008 Member For: 14y 3m 3d Gender: Male Posted 12/02/12 07:23 AM Share Posted 12/02/12 07:23 AM Can't help but there is a dude through eBay that does stuff to the ecu's so you can do what you wantIt was posted on here a couple of weeks ago, try searching for something, I can't help cos I forget Link to comment Share on other sites More sharing options...
MexicanBatman G666E Turbo!!! Member 1,008 Member For: 14y 3m 3d Gender: Male Posted 12/02/12 07:30 AM Share Posted 12/02/12 07:30 AM http://www.ebay.com.au/itm/Ford-Falcon-BA-BF-XR6-TURBO-ENGINE-ECU-RE-FLASHING-PATS-THEFT-disabled-/290667300642?pt=AU_Car_Parts_Accessories&hash=item43ad1f0722#ht_500wt_922So if you have this done already, just wack on a cable throttle body, and should be good? Link to comment Share on other sites More sharing options...
bionicxr6t05 Bronze Donating Members 2,216 Member For: 12y 8m 23d Gender: Male Posted 12/02/12 07:32 AM Share Posted 12/02/12 07:32 AM Piss the falcon computer off get a cable throttle body from plazmaman or the like and run an aftermarket ecu like haltec etc... Will make life way easier and do away with the need for retrofitting the pedals etc interesting conversion btw good luck!! Link to comment Share on other sites More sharing options...
zzz-ba ute Member 69 Member For: 14y 7m 21d Gender: Not Telling Posted 12/02/12 07:52 AM Author Share Posted 12/02/12 07:52 AM thanks guysI would like to try and keep the ford pcm so I can use all the functions on the auto. however the haltech does intrest mehas anyone had the ebay guy "flash" a computer for them?. and what haltech runs the dual vct. any idea on $$$.any help would be great. Link to comment Share on other sites More sharing options...
