bloosted Cruise Control 1,383 Member For: 18y 4m 17d Gender: Male Location: Adelaide Posted 13/11/11 01:26 AM Share Posted 13/11/11 01:26 AM hey all I just put kings ssl hd all round on my GT335 and the front ride height is 2mm higher than the standard and the rear dropped only 10mm , what a pain in the rear as I had sl's all round on my BA xr6 turbo and sl/ssl on my BF phoon and fg xr6 turbo....... hope the sag an inch or so :argue: Link to comment Share on other sites More sharing options...
xrlook Member 153 Member For: 15y 9m 2d Gender: Male Location: sydney Posted 13/11/11 02:15 AM Share Posted 13/11/11 02:15 AM Pic please ; ) Link to comment Share on other sites More sharing options...
Dillz Three pedals are better then two.. Donating Members 15,637 Member For: 16y 10m 28d Gender: Male Location: Melbourne Posted 13/11/11 02:35 AM Share Posted 13/11/11 02:35 AM SSL/SSSL is a good combo. Should of done your research. Link to comment Share on other sites More sharing options...
Henz Tampon inserted, Auto Acquired, next purchase a new handbag Donating Members 9,946 Member For: 16y 1m 3d Gender: Male Location: Vic Posted 13/11/11 02:39 AM Share Posted 13/11/11 02:39 AM SSSL all round and they still only just look lowered. The HDs wouldn't sag an inch though. Link to comment Share on other sites More sharing options...
MexicanBatman G666E Turbo!!! Member 1,008 Member For: 14y 3m 6d Gender: Male Posted 13/11/11 03:49 AM Share Posted 13/11/11 03:49 AM there is no front SSSLthere should be thoughmaybe try a standard 6 cyl spring, the hd ones are for the V8 cos they are heavier etc... but isnt the s/c v8 lighter than the old donk Link to comment Share on other sites More sharing options...
Guest XR09 Guests Posted 13/11/11 04:04 AM Share Posted 13/11/11 04:04 AM (edited) No it's still @ least 70kg heavier than the I6, ooops sorry yet it is just lighter than the old with all the kit on it. Edited 13/11/11 04:05 AM by XR09 Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 22d Gender: Male Location: Adelaide Posted 13/11/11 04:13 AM Share Posted 13/11/11 04:13 AM it was odd because the std springs were at least a inch taller than the kings and the new kings have the progressive rate tops on them now so it should sit lower by the inch minimum?so what it the best combo and part numbers ?pics would be good if anyone has done there gt335 and could have a definate answer cause atm the response is all over the place in regards to what is the go as above posts Link to comment Share on other sites More sharing options...
bloosted Cruise Control 1,383 Member For: 18y 4m 17d Gender: Male Location: Adelaide Posted 13/11/11 05:49 AM Author Share Posted 13/11/11 05:49 AM SSL/SSSL is a good combo. Should of done your research.I did and from pat , did you read I put ssl in the front and its higher :f*ckyou: Link to comment Share on other sites More sharing options...
Henz Tampon inserted, Auto Acquired, next purchase a new handbag Donating Members 9,946 Member For: 16y 1m 3d Gender: Male Location: Vic Posted 13/11/11 05:58 AM Share Posted 13/11/11 05:58 AM there is no front SSSLthere should be thoughmaybe try a standard 6 cyl spring, the hd ones are for the V8 cos they are heavier etc... but isnt the s/c v8 lighter than the old donkThen whatever the lowest fronts are then, which are...?? I had SSLs and they were nowhere near low enough, had them compressed and they were close enough. Same with rears for these cars, there all high too. Link to comment Share on other sites More sharing options...
Dillz Three pedals are better then two.. Donating Members 15,637 Member For: 16y 10m 28d Gender: Male Location: Melbourne Posted 13/11/11 06:28 AM Share Posted 13/11/11 06:28 AM Keep in mind B series and G series are completely different I think, so you can't compare them.I did and from pat , did you read I put ssl in the front and its higher Mine wasn't, either are any of the others I've seen. GT's must be different. Link to comment Share on other sites More sharing options...
