Thottle Stuck
lowroller
  • New Member
  • Member For: 13y 2m 9d
Was driving home tonight and gave the car a bit (nothing crazy) at a set of lights. While I was changing through the gears I noticed the engine was revving out when I put the clutch in (even though my right foot was off). So I put the clutch in, shifted into neutral, turned the engine off (It was revving up to 5000 or somewhere like that) and pulled off the road.
After I pulled over I tried to start it again and it was still revving high so I turned it off and waited some more. 15 minutes or so later it was back to normal and I drove home. Tried a few quick starts from standing now and then to replicate what happened but all seems normal..
Anyone else had this happen or know why it happened?
  • Sucker
  • Moderating Team
  • Member For: 19y 11m 4d
Only instances that I know of are from a rolled-up mat underneath the pedal.
The throttle position sensor apparently has a few fail-safes in it so wouldn't think that would be the cause, would assume you'd have a warning light and a dead pedal if it was faulty. :unsure:
Either way not something you want to stuff around with, best to get an expert's opinion ASAP.
  • New Member
I changed the floor mats from the ones I used to have because they used to roll over on the clutch side, but these ones haven't been doing it. When I pulled over I didn't notice the mat in a strange position..
Just a question.. If the mat rolls under the pedal, doesn't that stop you from being able to accelerate rather than stopping the pedal from coming back up?
I might take the driver side mat out altogether just to be sure and drive cautious for a while.
  • New Member
I think I can safely say it's not the floor mat after last night.
I was driving slowly when I noticed I had no acceleration and the ETC warning light was on. The speedo wasn't working before this happened either, but I wasn't driving far or fast so I ignored that (it always starts working again after I turn the ignition off and on again)
So I pulled over and turned the key off and on, all was normal again..
A trip to Ford, huh?
  • Sucker
  • Moderating Team
Nah...just keep driving it till you either end up in a wall or a ditch.
Why bother getting something as serious as a faulty accelerator pedal looked at...waste of time and money.
