Moose Member 185 Member For: 15y 11m 12d Gender: Male Location: Ipswich, QLD Posted 03/08/11 09:55 PM Share Posted 03/08/11 09:55 PM (edited) Double post, damn pc Edited 03/08/11 09:59 PM by Moose Link to comment Share on other sites More sharing options...
07ToxicF6 Member 18 Member For: 12y 7m 27d Gender: Male Location: Victoria, the place to be defected. Posted 04/08/11 03:00 AM Author Share Posted 04/08/11 03:00 AM ford had another look today, load of codes, some knok codes pointing to pcm, I hope its not a faulty pcm! Ford said there a miss comunication "in the circuit of things..." and said its costly to weed out...grrreat. Link to comment Share on other sites More sharing options...
Moose Member 185 Member For: 15y 11m 12d Gender: Male Location: Ipswich, QLD Posted 04/08/11 03:30 AM Share Posted 04/08/11 03:30 AM ford had another look today, load of codes, some knok codes pointing to pcm, I hope its not a faulty pcm! Ford said there a miss comunication "in the circuit of things..." and said its costly to weed out...grrreat.That is also the same info I've been told... faulty PCM and ECM (I think that's it). Mine also brings up loads of fault codes, even silly ones like the rear heater lines not working or the seat electrics being faulty. Mine also has a 'miss-communication' between the speed sensors and the ECU - have been told that because our cars run on a 'closed loop' wiring circuit, if a wire is cut or a plug left unplugged or even a bent pin, and it cant complete the loop, this will happen. But then you've gotta track down which wire/plug is doing it, cuz fault checking wont tell you!Then to top it off, I've done the same as you, gone to ford and been told the same thing, costly to find (could come down to a re-wire of the car). Got my car booked in with my mechanic next Wednesday before it goes to Elite Auto and he's going to do one final check over it, make sure there is nothing amiss, check the ECU and the ABS stuff, check plugs etc etc.Can I ask, did this just start happening for you? Or was it after some work was done? Or even a service? Link to comment Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 14y 2m 11d Gender: Male Location: Christchurch, New Zealand Posted 04/08/11 05:48 AM Share Posted 04/08/11 05:48 AM I believe the speedo gets its reading from the rh rear sensor and abs uses all the sensors. As for tracking a broken wire or bent pin or cut in the system a continuity check would tell ya stuff (think its continuity) but will be very time consuming.If you have the skills and wiring diagrams you can hook up a multimeter at end end of a circuit on each wire and see if one isnt talking, from there you would have to track along a problem wire at each join ((plug) that's if you find a issue) to find when it gets continuity again to tell you where the problem is located.As I said very time consuming. Link to comment Share on other sites More sharing options...
07ToxicF6 Member 18 Member For: 12y 7m 27d Gender: Male Location: Victoria, the place to be defected. Posted 04/08/11 07:01 AM Author Share Posted 04/08/11 07:01 AM jus random recently bro out of the blue.. Link to comment Share on other sites More sharing options...
Purnong Inactive Members 1 Member For: 12y 9m 10d Posted 10/08/11 09:38 AM Share Posted 10/08/11 09:38 AM (edited) have been told that because our cars run on a 'closed loop' wiring circuit, if a wire is cut or a plug left unplugged or even a bent pin, and it cant complete the loop, this will happen. But then you've gotta track down which wire/plug is doing it, cuz fault checking wont tell you!This might be out of left field but could be worth a look, Do both of you have towbars fitted?Reason I ask is I just discovered the dealer used Scotchlocks on my wiring loom to wire in the trailer plug, These things are notorious for creating a bad connection and even cutting the wires they are joined toIt is possible that the earth or brake light wire might be cut if yours has been done like mine, Longshot but cheap to look Edited 10/08/11 09:39 AM by Purnong Link to comment Share on other sites More sharing options...
Moose Member 185 Member For: 15y 11m 12d Gender: Male Location: Ipswich, QLD Posted 10/08/11 11:00 PM Share Posted 10/08/11 11:00 PM Nah no tow bar mate, but I have an aftermarket head unit installed. However, this was installed a long time ago and the problem has only just come up now! Link to comment Share on other sites More sharing options...
07ToxicF6 Member 18 Member For: 12y 7m 27d Gender: Male Location: Victoria, the place to be defected. Posted 11/08/11 03:53 AM Author Share Posted 11/08/11 03:53 AM I cant belive no one else knows of our issue moose :( this is stressin me out, went for a drive last nite wen it was raining, as soon as it loses traction it goes nuts, I hope its a cheap fix.. Link to comment Share on other sites More sharing options...
Moose Member 185 Member For: 15y 11m 12d Gender: Male Location: Ipswich, QLD Posted 15/08/11 01:00 AM Share Posted 15/08/11 01:00 AM Elite Auto found my problem - spark plugs weren't gapped out properly. They re-gapped them, went for a drive, problem fixed. First time they've seen it caused by this, normally its the coil-packs or the leads! They said its not normally an ABS issue. Link to comment Share on other sites More sharing options...
07ToxicF6 Member 18 Member For: 12y 7m 27d Gender: Male Location: Victoria, the place to be defected. Posted 16/08/11 04:07 AM Author Share Posted 16/08/11 04:07 AM what about speedo dropin out? Link to comment Share on other sites More sharing options...
