Rancidpunx Brisbanes Resident Detailer Donating Members 950 Member For: 15y 3m 3d Gender: Male Location: In my Cabin Outside Brisbane. Posted 23/07/11 08:34 AM Share Posted 23/07/11 08:34 AM Can anyone point me in the direction of a wire I can tap into for Lighting my gauges in an FG?From my understanding the B series had access to a button for ?foggies? that you could take the 12v dash lighting from, but where can I get it from on an FG? Im taking 12v ignition power from the Ciggy lighter (blue wire), I hope that's right but where do you think a good earth connection is whilst we are here?Cheers Link to comment Share on other sites More sharing options...
Gussa Donating Members 220 Member For: 13y 2m 19d Gender: Male Location: Gippsland Posted 23/07/11 02:11 PM Share Posted 23/07/11 02:11 PM I am in the same boat - I will probably just use the cig +12v inline with a potentiometer. Then ill just manually adjust to the dim level because I don't really change the brightness very often.As for the Negative - I personally will just be using the same as the cig lighter (can't see any problems doing so). Link to comment Share on other sites More sharing options...
Rancidpunx Brisbanes Resident Detailer Donating Members 950 Member For: 15y 3m 3d Gender: Male Location: In my Cabin Outside Brisbane. Posted 23/07/11 10:16 PM Author Share Posted 23/07/11 10:16 PM Yeah ive used the ciggy lighter for power and earth just wondered if there was anywhere better. Ive taken the shroud off from around the steering column but cant distinguish whats what. Dont really want to be cutting things without a heads up especially with the airbag. May just have to run a cable from the headlight wiring direct. Link to comment Share on other sites More sharing options...
Slash Donkey Dick Member 801 Member For: 14y 1m 4d Gender: Male Posted 23/07/11 10:57 PM Share Posted 23/07/11 10:57 PM For $100, any auto-electrician will have them wired in properly. Just mount the pod/guages/senders & drop it off Link to comment Share on other sites More sharing options...
Rancidpunx Brisbanes Resident Detailer Donating Members 950 Member For: 15y 3m 3d Gender: Male Location: In my Cabin Outside Brisbane. Posted 23/07/11 11:28 PM Author Share Posted 23/07/11 11:28 PM If it was $100 then that's fine, but everyones posts on gauge installs are $400-$500, someone else had a quote of $750.Ive got them in and the 3 power cables and 3 lighting cables connected into single wires. Will see if theres someone local that can just hook up to a 12v lighting circuit. Link to comment Share on other sites More sharing options...
Slash Donkey Dick Member 801 Member For: 14y 1m 4d Gender: Male Posted 23/07/11 11:30 PM Share Posted 23/07/11 11:30 PM As I said, $100 if you install guages/pod/senders & they just have to run wires. $750 would have been for mounting everything, wiring up, lunch break & then a lap dance Link to comment Share on other sites More sharing options...
Rancidpunx Brisbanes Resident Detailer Donating Members 950 Member For: 15y 3m 3d Gender: Male Location: In my Cabin Outside Brisbane. Posted 24/07/11 01:41 AM Author Share Posted 24/07/11 01:41 AM Just tried the lights wired into the power so lights are on all the time with ignition, dont think its to bad so may just leave it like that. Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 23d Gender: Male Location: Adelaide Posted 24/07/11 01:48 AM Share Posted 24/07/11 01:48 AM bud I just wired them in the same so when acc is on so is the lights couldnt be arsed finding the light cct cable Link to comment Share on other sites More sharing options...
