LazyBrennan Donating Members 683 Member For: 13y 1m 2d Gender: Male Location: Baldivis, Wait Ages. Posted 28/06/11 10:43 AM Share Posted 28/06/11 10:43 AM Ok so can someone please explain to me how a bigger sway bar improves handling? I am looking at getting a white line 27mm sway bar for the front. Link to comment Share on other sites More sharing options...
Guest XR09 Guests Posted 28/06/11 12:05 PM Share Posted 28/06/11 12:05 PM A sway bar is there to assist the springs. In a way. What it does is transfer tension across the car. Basically compressing the inside spring to keep the car flatter in a turn.So in theory it tries to keep the inside front wheel flatter on the ground. Well that's my basic knowledge of it anywho. Probably wrong. Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 17y 10m 27d Gender: Male Location: @ my laptop Posted 28/06/11 12:26 PM Share Posted 28/06/11 12:26 PM they help to control body roll and move grip from 1 end of the car to the other, ie put a stiffer front sway bar on and you will get more rear corner grip at the risk of less front grip Link to comment Share on other sites More sharing options...
Banned1 Banned Banned 734 Member For: 13y 7m 11d Gender: Male Location: Caloundra Posted 28/06/11 01:03 PM Share Posted 28/06/11 01:03 PM as the title says.....SWAY bar. or more info in the Uk version. ANTI-ROLL bar. thicker bar will generally mean less body roll , keeping car flatter through bends. Link to comment Share on other sites More sharing options...
JGP Donating Members 309 Member For: 13y 7m 26d Gender: Male Posted 18/11/11 04:40 AM Share Posted 18/11/11 04:40 AM If your going to replace the front sway bar, what bushes should you also replace? my car has done 52000ks Link to comment Share on other sites More sharing options...
Tobey Awesome... Member 407 Member For: 13y 9m 19d Gender: Male Posted 18/11/11 05:33 AM Share Posted 18/11/11 05:33 AM If your going to replace the front sway bar, what bushes should you also replace? my car has done 52000ksAt the same time? It comes with the bushes you need to replace on the actual sway bar. But there is heaps of other bushes, but they aren't any easier to replace with the sway bar off.To improve handling however, I would do the lower control arm bushes in a urethane bush (superpro), they are a soft hydraulic filled bush that are good for quietness, but not much else. It will make the car track better, and not 'wander' as much, it will also save the insides of your tyres under braking.If you like to keep road noise down and have some comfort left, leave the other front end bushings as rubber.The lower bushes are best done by a mechanic as they are a pain in the arse to do. Link to comment Share on other sites More sharing options...
knoles Donating Members 390 Member For: 13y 1m 7d Gender: Male Location: Port Hedland Posted 18/11/11 09:39 AM Share Posted 18/11/11 09:39 AM I did all the front bushes bar the strut bushes with superpro last weekend and I love how it is now. Minimal downside to huge improvement. Cost me $400 for all bushes and ball joints did the majority of the work myself and paid $100 to get some of the bushes pressed in. Probably one of the best bang for buck mods ive done and will not have to worry about them for quite a while. Also the reduced tyre wear will pay for them over time. Link to comment Share on other sites More sharing options...
Barnesy Donating Members 210 Member For: 15y 3m 3d Gender: Male Location: Brisbane Posted 18/11/11 09:59 AM Share Posted 18/11/11 09:59 AM I have I have notices significant improved rear end grip with 27mm, especially in the wet, but have noticed a bit of under steer through some tight turns especially round abouts. IMO if you have under-steer you are going to hot into the corner. I might invest in some 22mm rears and see if there is some improvement to reduce under-steer. Link to comment Share on other sites More sharing options...
sexual harrassment panda I see a red door and I want to paint it black Donating Members 5,919 Member For: 14y 5m 29d Gender: Male Location: Far north queensland Posted 18/11/11 11:12 AM Share Posted 18/11/11 11:12 AM do you have stock bushes and springs and shocks? Link to comment Share on other sites More sharing options...
JGP Donating Members 309 Member For: 13y 7m 26d Gender: Male Posted 18/11/11 11:04 PM Share Posted 18/11/11 11:04 PM do you have stock bushes and springs and shocks?Yes Link to comment Share on other sites More sharing options...
