TotallyHaggard Member 26 Member For: 13y 22d Gender: Male Posted 17/08/11 01:35 AM Share Posted 17/08/11 01:35 AM I was actually going to recommend soldering the wires back in, mine had come loose at some point but that being said I am a bit of a hack and may have damaged the plastic holding the wire in. Link to comment Share on other sites More sharing options...
mick1378 Member 14 Member For: 13y 1m 29d Gender: Male Posted 10/09/11 06:43 AM Share Posted 10/09/11 06:43 AM I will definetly have to give this a crack as I have replaced factory sub with clarion free air sub (marine) in my opinion made no real diffrence I do however think there is enough room to possibly stick a 10"in place of 8" sub with a bit of tweeking of the mount, but it was prob about a year ago when I actually changed it so my recollection of how it looked (setup) could be off a little. Link to comment Share on other sites More sharing options...
mick1378 Member 14 Member For: 13y 1m 29d Gender: Male Posted 10/09/11 07:35 AM Share Posted 10/09/11 07:35 AM Straight after reading post went out swapped wires around and in my opinnion makes a hugh difference. I normally have bass in equalizer (treb/mid/bass) on prob 2 clicks on positive side of middle line and if volume is up prob 25 that's the limit before it starts distorting. after swapping turned bass up at almost on max on equalizer and volume prob 28 before it wants to start distorting. Link to comment Share on other sites More sharing options...
smicky Go Pies!!! Donating Members 2,852 Member For: 16y 2m 8d Gender: Male Location: Vic Somewhere - Sometimes NSW Posted 10/09/11 03:03 PM Share Posted 10/09/11 03:03 PM Many high end A/M H/U's offer this as a setting option within the config menu.It 'will' typically have 'some' effect, however if this is the only 'wire' being changed and no other settings or tone controls adjusted, it typically is a small change in what you will hear. Turning the bass control up will also carry further and greater effect on the system, as well as that of the wire change should both things be done.Having said that - 1. I dont have a FG, rather had a BFII. 2. Dont own the BFII anymore either. 3. Cant test to advise based on both points 1 + 2. Lol...Anyways:"Phase controlChanging the relative phase of the subwoofer with respect to the woofers in other speakers may or may not help to minimize unwanted destructive acoustic interference in the frequency region covered by both subwoofer and main speakers. It may not help at all frequencies, and may create further problems with frequency response, but is even so generally provided as an adjustment for subwoofer amplifiers.[22] Phase control circuits may be a simple polarity reversal switch or a more complex continuously variable circuits.Continuously variable phase control circuits are common in subwoofer amplifiers, and may be found in crossovers and as do-it-yourself electronics projects. Phase controls allow the listener to change the arrival time of the subwoofer sound waves relative to the same frequencies from the main speakers (I.e., at and around the crossover point to the subwoofer). A similar effect can be achieved with the delay control on many home theater receivers. The subwoofer phase control found on many subwoofer amplifiers is actually a polarity inversion switch.[28] It allows users to reverse the polarity of the subwoofer relative to the audio signal it is being given. This type of control allows the subwoofer to either be in phase with the source signal, or 180 degrees out of phase.The subwoofer phase can still be changed by moving the subwoofer closer to or further from the listening position, however this may not be always practical." Link to comment Share on other sites More sharing options...
CLuTZ Donating Members 227 Member For: 12y 11m 9d Gender: Male Location: Melbourne Posted 22/09/11 02:36 AM Share Posted 22/09/11 02:36 AM Just performed the fix on my G6E. Such a difference! The 3 white clips were easy to pull off the rear trim in the boot exposing the sub. On the plug there's another little clip that you need to remove before you can get the wires to come loose. Thanks for the idea! 1 Link to comment Share on other sites More sharing options...
spite New Member 6 Member For: 12y 7m 20d Posted 28/09/11 06:44 AM Share Posted 28/09/11 06:44 AM Seems to make a difference to my system! Link to comment Share on other sites More sharing options...
Tockley Member 51 Member For: 15y 6m 23d Gender: Male Location: Melbourne Posted 19/10/11 02:57 AM Share Posted 19/10/11 02:57 AM Just curious - I will be replacing my sub with the 8" Kicker direct replacement. Should I still reverse the wires? Link to comment Share on other sites More sharing options...
RHR BOOST Moderating Team 5,698 Member For: 20y 7m 20d Gender: Male Location: Southern Highlands NSW Posted 19/10/11 04:18 AM Author Share Posted 19/10/11 04:18 AM Only one way to find out. Link to comment Share on other sites More sharing options...
MattLacey Member 28 Member For: 12y 7m 7d Gender: Male Location: Melbourne Posted 01/11/11 06:16 AM Share Posted 01/11/11 06:16 AM Finally got around to doing this today, was starting to doubt whether it'd be worthwhile given some of the comments I've read, but I've gotta say, holy hell does this improve the system. There must have been a manufacturing error at play here, I've read about subs pushing or pulling, but the other thing to think about here is destructive interference. Given that the sub in the FG (not sure about other models) is pumping straight into the cabin, if it was out of phase with the rears then it would definitely cause destructive wave patterns and so can cause major quality issues. Once I had two 6x9's in a parcel shelf wired out of phase with each other by accident, it took about 5 seconds to realise something was up.So yep, another happy FG premium sound owner — this really does make a very obvious difference (especially when listening to Leftfield ) Link to comment Share on other sites More sharing options...
aviator Member 26 Member For: 14y 1m 28d Gender: Male Location: Sydney Posted 01/11/11 07:40 AM Share Posted 01/11/11 07:40 AM Just did this aswell, made a big difference, now sounds how it should being a 'Premium' system. Cheers guys, this was one thing that bothered me about the car. Link to comment Share on other sites More sharing options...
