aaronm Member 2 Member For: 14y 5m 21d Posted 28/01/11 10:20 AM Share Posted 28/01/11 10:20 AM I had the factory clutch replaced in my 03 ba xr6t with a aftermarket hd clutch about 1 yr ago and the mechanic said he had to blow out the clutch line with air and a whole heap of thick gooey chunks of sh*t sprayed out every where, he also said I should look at doing it again after a few months which I never got around to. was wondering if this was common, what causes this and how to go about blowing it out again? Link to comment https://www.fordxr6turbo.com/forum/topic/72930-clutch-line-blockage/ Share on other sites More sharing options...
BBQBurner Member 5 Member For: 17y 3m 6d Posted 26/06/11 03:48 AM Share Posted 26/06/11 03:48 AM sounds like you have never changed your clutch fluid.you should change it at least everytime you change you brake fluid. Link to comment https://www.fordxr6turbo.com/forum/topic/72930-clutch-line-blockage/#findComment-1117575 Share on other sites More sharing options...
