  • Member For: 16y 9m 11d
hey guys I was under the car today and the rubber flex joint between the tailshaft and tranny is looking a bit shagged, does anyone know where I can get a replacement?
This is the pic out of the workshop manual
Looks to me that you just undo the bolts, slip the bit out and chuck the new one in,
Anyone chucked one in that can tell me if that's all that's involved:)
Cheers
If anyone has what was the flex joint price?
https://www.fordxr6turbo.com/forum/topic/72710-flex-joint/
  • Member For: 18y 6m 5d
Apparently the Late model camira v8 one fits and is slightly stronger and cheaper?
I enquired a while ago, but because engine let go I did not get one.
Think they where something like $250 from ford?
And auto shops not far behind.
Tried a tailshaft manufacture here in QLD and was told V8 Late model camira and $150?
Hard to imagine that small bit of rubber taking all the power and torque these cars put out.
https://www.fordxr6turbo.com/forum/topic/72710-flex-joint/#findComment-1073200
Cheers 01txr,
Yeah they are a tough little unit, even all the big machinery I work on has them 100t+ and surprisingly they don't fail very much, but like anything once it does let go......
https://www.fordxr6turbo.com/forum/topic/72710-flex-joint/#findComment-1073244
Yeah it's all good, I jacked up the back so I could spin the shaft
Then I slid under and noted the shaft position and started undoing the bolts
(looking pretty shagged)
I then undone the rest of the bolts and grabbed both shafts and pulled them apart till there was clearance to pull the short shaft down and it popped strait off
So its obviously fingered, I got ordered one from coventrys (in Perth) for 213.70 I think it was, won't rock up till tomorrow morn when I fit it
https://www.fordxr6turbo.com/forum/topic/72710-flex-joint/#findComment-1073457
  • Member For: 18y 8m 12d
Haha that is pretty stuffed!
I have replaced mine before but just got one from the wreckers for $80, as ford told me it comes with the tailshaft? Ah gotta love ford!
Mine only had small cracks or tears in it..
https://www.fordxr6turbo.com/forum/topic/72710-flex-joint/#findComment-1073578
Well all fitted no worries besides being given the wrong part 3 times...... Just tell them it's a v8 if you have to go in there..... Or they will give you taxi spec :)
This is the correct part number for the turbos and v8
https://www.fordxr6turbo.com/forum/topic/72710-flex-joint/#findComment-1073935
