Fg Xr6T Ute & 20 Inch Rims- Offset And Tyres Question?
jthomasl
  • 6 years later...
  • Member For: 5y 3m 8d
Hi Fellas,
When I was searching for rims for my fg ute.
I came across this forum which helped a lot thanks btw.
FYI
I'm currently running koya sf11 20"x9 on front with offset 22 or koya call it ET I think. 245x35zr20. On the rear 20x10.5 offset of 22. 275x30zr20.
I'm getting the guards rolled later on when I go to lower it about 30mm
Hope this helps
Cheers
  • XR50T
  • Member For: 10y 10m 27d
It will bulge out slightly.
Drive hard it could cause some unwanted movement.
Put enough pressure in to prevent this and you'll slide everywhere.
Use willtheyfit.com to give you an idea. Some tyre brands are wider in the shoulder than others so you've got to sus that out to go real wide.
