  • Member For: 16y 5m 21d
One thing to note is when you connect the battery properly it will click and your lights will flash on and off. For whatever reason, I have had the same issue where pulling out the battery and putting it back in, it doesn't always connect up properly even if everything is on tight. Pull the clamps off and put them on again until you hear that click / see the lights flash.
I dare say the battery hasn't been connected properly.
  • Member For: 18y 1m 12d
now the car seems to have "immobilised" itself.
Hey mate,
If the car has been immobilised, the dash would light up as usual. But, when you try starting the car, the red symbol of the hand would start flashing rapidly, indicating immobilisation. As suggested above, check that the battery has charge and that the connections are secure. If that fails, start checking the fuses in the engine bay.
Cheers,
Phooned
  • Member For: 15y 6m 1d
Also just for the sake of it connect the battery negative first then the Positive side.
  • 8 years later...
  • Member For: 6y 2m 7d
Hi guy's I have a 2005 bf falcon ive recently changed the battery on the key les remote then I a day later I was starting my car trun the key had power but no crank can any one tell what's the problem cheers
