4DZILR Donating Members 713 Member For: 14y 2m 14d Gender: Male Location: Sydney - Brighton Le Sands Posted 14/08/10 01:39 PM Share Posted 14/08/10 01:39 PM I dont think removing or unplugging it would determine the fault mate.If its not plugged in, then I would think the cycle wont complete meaning it would still give you the same response.. You need to actually test the current.. if it makes it to the actuator and other parts to test if its electricity coming through Link to comment Share on other sites More sharing options...
nzturbo Member 26 Member For: 14y 6m 12d Gender: Male Location: NZ Posted 14/08/10 08:49 PM Author Share Posted 14/08/10 08:49 PM Just check ing there in case of a loose plug.Had fault breifly twice before.Now all the time.........have a multi meter but actuaters seem to be switching fine.One step closer to a visit to fraud Link to comment Share on other sites More sharing options...
nzturbo Member 26 Member For: 14y 6m 12d Gender: Male Location: NZ Posted 01/09/10 05:34 AM Author Share Posted 01/09/10 05:34 AM (edited) Had to sparky, plugged in his thingy and up came a fault from LH door wiring.He was able to lock doors thru his thingy too.Did mention the BCM too.Will have to remove door and check plug next .If no joy ,at least I have found a gud sparky. Edited 01/09/10 05:37 AM by nzturbo Link to comment Share on other sites More sharing options...
beast_man88 Member 7 Member For: 13y 6m 29d Gender: Male Posted 03/10/10 03:35 AM Share Posted 03/10/10 03:35 AM mine does this when I give it a thorough wash around doors and handles. I just remove battery terminal for a while and then all is good. not sure why it does it. it happend to me on the way to work after washing it and I didnt want the interior light draining the battery so I removed battery terminal after work I reconnected and all was good, its happend maybe 3 times now and removing that batt for an hour should fix it. Link to comment Share on other sites More sharing options...
PSI40L Member 175 Member For: 21y 4m 1d Posted 03/11/10 12:29 PM Share Posted 03/11/10 12:29 PM this is definitely a bem module problem have seen this many times remember when u get another bem module it has to be grafted to your pcm otherwise car wont start and icc wont work bem is located under the cd player on the icc Link to comment Share on other sites More sharing options...
Scoobi New Member 6 Member For: 16y 4m 15d Gender: Male Location: Wellington, NZ Posted 23/11/10 10:18 PM Share Posted 23/11/10 10:18 PM Hey nzturbo my ute is doing exactly the same thing as yours. Have you had any success yet with yours? Link to comment Share on other sites More sharing options...
hawlass Silver Donating Members 1,161 Member For: 16y 5m 10d Gender: Male Location: left right out Posted 26/08/11 07:38 PM Share Posted 26/08/11 07:38 PM (edited) Any luck with a fix yet? Mate of mine having the same trouble now! Edited 26/08/11 07:41 PM by hawlass Link to comment Share on other sites More sharing options...
nzturbo Member 26 Member For: 14y 6m 12d Gender: Male Location: NZ Posted 25/05/12 05:43 AM Author Share Posted 25/05/12 05:43 AM Just add this , sorry bit late.Put brand new after market BCM module in and everything all gud now.Cost me $838 NZ fitted.cheers for your imput fellas. Link to comment Share on other sites More sharing options...
