KLR250 Member 60 Member For: 14y 9d Posted 09/07/10 02:39 AM Share Posted 09/07/10 02:39 AM I'm going to install my process west surge and 044 this weekend,I dont have the pw loom so I'll be making my own.where is the best place to find the factory fuel pump wire (and colours would be awesome) on my bf2 11/06 xr6t.cheers Link to comment Share on other sites More sharing options...
HI PSI Member 1,572 Member For: 17y 10m 30d Gender: Male Location: Central Queensland Posted 09/07/10 02:51 AM Share Posted 09/07/10 02:51 AM I used double insulated power wire . Use the pink wire off the fuel pump relay in the engine bay. It is a timed relay and shuts the fuel pump down after around 3-4 seconds of priming.This feature comes in handy when loading tunes into the car. As the fuel pump would run continuously otherwise. If you take the metal screw tab off the relay (If fitted) You can fit the relay onto a tab inside the fuse/relay box and make it look factory.. I ran the wire forwards and then throught he inner gueard. Between the plastic guard and the chassis. It come back through the inner gueard near the brake booster then across the back of the engine with the brake lines...I personally have only one problem with this setup. My fuel pump seems to shut down if I start the car and let it idle. If don't start driving immediately and will do this 2-3 times then it is fine.. If I drive off immediately it is fine... Go figure.. Maybe I need a one way check vale put between the pump and the fuel rail... I hope that this helps Link to comment Share on other sites More sharing options...
bjc Donating Members 2,812 Member For: 20y 7m 20d Gender: Male Location: Townsville Posted 09/07/10 04:10 AM Share Posted 09/07/10 04:10 AM Splice into the pink wire where HI PSI has said.I just put my relay with the fuel pump and surge tank itself and connected it to the bolt that holds the fuel pump bracket. Earth wire connected to one of the main bolt brackets of the surge tank and 12v power from the starter motor with a fuse inline. The only long wire for me then was the factory fuel pump wire run the same way as HI PSI with conduit wrapped around it! Link to comment Share on other sites More sharing options...
KLR250 Member 60 Member For: 14y 9d Posted 09/07/10 09:02 AM Author Share Posted 09/07/10 09:02 AM thanks heaps guys Link to comment Share on other sites More sharing options...
RAP1D Member Donating Members 3,739 Member For: 17y 11m 4d Gender: Male Location: Sydney NSW Posted 10/07/10 09:07 AM Share Posted 10/07/10 09:07 AM Call PW, they'll be happy to help out mate. Link to comment Share on other sites More sharing options...
234Fpv Donating Members 522 Member For: 12y 9m 16d Gender: Male Location: Yeppoon qld Posted 10/04/12 10:57 AM Share Posted 10/04/12 10:57 AM Is this the same for a fg? 1 Link to comment Share on other sites More sharing options...
bjc Donating Members 2,812 Member For: 20y 7m 20d Gender: Male Location: Townsville Posted 10/04/12 10:51 PM Share Posted 10/04/12 10:51 PM Give Dave a call or text as he will know but cant see it being any different Link to comment Share on other sites More sharing options...
234Fpv Donating Members 522 Member For: 12y 9m 16d Gender: Male Location: Yeppoon qld Posted 11/04/12 10:16 AM Share Posted 11/04/12 10:16 AM Yeah I'll be seeing Dave next week when I pick the surge tank and valve springs up. Just thought I'd get what info I could off here. The pw harness just seems a bit pricey for something I could do myself. 1 Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 24d Gender: Male Location: Adelaide Posted 11/04/12 10:38 AM Share Posted 11/04/12 10:38 AM yes its the same b series to f series Link to comment Share on other sites More sharing options...
234Fpv Donating Members 522 Member For: 12y 9m 16d Gender: Male Location: Yeppoon qld Posted 11/04/12 10:39 AM Share Posted 11/04/12 10:39 AM Awesome. Cheers Link to comment Share on other sites More sharing options...
