berzerker Donating Members 767 Member For: 16y 4m 4d Gender: Male Location: Brisbane Posted 28/06/10 02:17 AM Share Posted 28/06/10 02:17 AM Hi allIve had 5 or 6 cds stuck or lodged in my preium sound icc for a while now. Just been using the ipod to listen to tunes, but quality isnt the same.Really want them OUT now. It just reads on the display 'no disc' when I push eject it makes a sound like cds are trying to come out but it just reads 'no disc' again after 10 seconds.Do I need to remove ICC to get these out? Is there an easier way?Cheers Link to comment Share on other sites More sharing options...
Yoshi Donating Members 136 Member For: 15y 3d Gender: Male Location: Knox Posted 28/06/10 08:37 AM Share Posted 28/06/10 08:37 AM Had CD's stuck in my stacker, Had to remove the ICC and push the CD's out from behind manually. Link to comment Share on other sites More sharing options...
RHR BOOST Moderating Team 5,698 Member For: 20y 7m 20d Gender: Male Location: Southern Highlands NSW Posted 28/06/10 10:18 AM Share Posted 28/06/10 10:18 AM Sounds like its gotta come out. If you take it out what ever you DO NOT TURN THE ICC UPSIDE DOWN. There is a sticker on the unseen part of thr ICC from memory.Not sure if this is correct but if it is turned upside down you can pretty much throw the thing away Link to comment Share on other sites More sharing options...
EvilDaifu Cruise Whore Moderating Team 5,128 Member For: 18y 8m 19d Gender: Male Location: Melbourne Posted 28/06/10 11:53 AM Share Posted 28/06/10 11:53 AM I don't understand why the ICC must not be turned upside down. Does anybody know? What sort of transducer is there in the ICC that is sensitive to orientation - something that controls the air-bags perhaps?Reason I am asking is that I was tempted at one stage to remove my ICC but didn't know I had to be that careful with handling it Link to comment Share on other sites More sharing options...
RHR BOOST Moderating Team 5,698 Member For: 20y 7m 20d Gender: Male Location: Southern Highlands NSW Posted 28/06/10 12:02 PM Share Posted 28/06/10 12:02 PM Just keep it upright and it will be fine. Been there done that and it was ok Link to comment Share on other sites More sharing options...
jacko487 Member 2 Member For: 13y 9m 18d Posted 10/07/10 11:54 PM Share Posted 10/07/10 11:54 PM Hi allIve had 5 or 6 cds stuck or lodged in my preium sound icc for a while now. Just been using the ipod to listen to tunes, but quality isnt the same.Really want them OUT now. It just reads on the display 'no disc' when I push eject it makes a sound like cds are trying to come out but it just reads 'no disc' again after 10 seconds.Do I need to remove ICC to get these out? Is there an easier way?CheersG'Day mate I had a cd stuck in my g6e turbo,it also read no disk ,so I just disconnected the battery then left it for a few minutes reconnected and all was fine ,it must have reset it's self. worth a try before dismantling it ,good luck. Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 16y 5m Gender: Male Location: Probably above atmospheric pressure Posted 11/07/10 01:15 AM Share Posted 11/07/10 01:15 AM If you take it out what ever you DO NOT TURN THE ICC UPSIDE DOWNJesus, never knew that! Will be handy info when installing gauges.Is this only for premium ICC or both? Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 18y 7m 2d Gender: Male Location: Perth Posted 11/07/10 01:18 AM Share Posted 11/07/10 01:18 AM Both. take all the CD's out before you remove it. Once thats done you can do somersaults with it in your top pocket for all the ICC cares. The cd's drop out and jam the stacker up if you tip it when its full Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 16y 5m Gender: Male Location: Probably above atmospheric pressure Posted 11/07/10 01:30 AM Share Posted 11/07/10 01:30 AM Mental note: don't drive a loop-the-loop with a CD playing. 2 Link to comment Share on other sites More sharing options...
EvilDaifu Cruise Whore Moderating Team 5,128 Member For: 18y 8m 19d Gender: Male Location: Melbourne Posted 22/12/10 10:43 AM Share Posted 22/12/10 10:43 AM Dam, what is it with these CD stackers. Mines the stock 6 stacker and now it's jammed again. First time it jammed was on the VIC Yarra Christmas cruise. But it came good again at the end of the cruise. Dillz says it happened to him and he just kept pushing the CD eject button until one day a CD popped out and all was good again. I did the same thing and a CD popped out and it came good again ... until today Farrked if I know why it does it - was a bit warm outside today and the car was parked out in the constant sun the past few days - thinking one of the 5 CDs in the 6 stacker has warped slightly. Dillz reckons it happens with CDs you've burnt yourself which is the case for all 5 in my stacker. Yoshi was on the Yarra cruise as well and reckons you have to take the ICC out and push the CDs out manually from he back. Says he's done that once before and ummm has to do it again cos he's got a stuck stacker as well again. So, what's with these - sounds like a common problem. Yeah, Adam tried the disconnecting of the battery for a little while but that didn't work - maybe because mine's a BA and not the stacker used in the prem sound for the FG?Anyway, looked at this thread about changing the headend unit and it shows how to remove the ICC - so may give this a go in some spare time coming up over the Christmast break. Just annoys me cos one of the reasons I was influenced to buy this car was that it had the stacker. In my previous XR6Ts - they all had single CD players - so never had this issue. Ah well If I get stuck, may have to ring you Yoshi or Adam Link to comment Share on other sites More sharing options...
