cv8z Member 125 Member For: 17y 10m 5d Location: Brisvagas Posted 21/06/10 03:26 AM Share Posted 21/06/10 03:26 AM Hi Guys/galsMy engine is worn out on my BF FPV Typhoon R Spec.I am chasing another engine to put into the car, The problem im hving is the engine is putting out 4000rwkw'sMy question to the forum is, What are the differences between the FPV and Xr6t engines???Also apart from the sum is there any difference between the xr6t FG engine ?Cheers Link to comment Share on other sites More sharing options...
icer Banned 2,335 Member For: 14y 9m 7d Gender: Male Location: Aspendale, Vic. Posted 21/06/10 03:42 AM Share Posted 21/06/10 03:42 AM (edited) 4000rwkw on the bf stock motor will do that.... maybe try a jet engine out of a space ship?from my understanding, there is stronger parts in the bf motor AFTER 06/06 builds. Rods, valve springs etc. And even stronger in the FG. The fg xr6t and f6 short block are the same. Both should be fine for 400rwkw.You can go a fg short and your bf head if you where chasing something. Or just go an atomic motor.Is your problem too many Ks? or way to much lead foot over time? Cant just die in the bum after 5000km pushign those numbers.... Maybe after a few years of constant abuse? Edited 21/06/10 03:43 AM by icer Link to comment Share on other sites More sharing options...
MILES Donating Members 103 Member For: 15y 11m 17d Gender: Male Location: Townsville Posted 21/06/10 04:45 AM Share Posted 21/06/10 04:45 AM 4000rwkw would have torn your car a new arsehole. Did The ZF hold up to that much power ok? What exactly do you mean by worn out, how long has it been copping a thrashing for? I'm doing mine up right now to a similiar power level, I'm just wondering what sorta shelf life I might expect. Link to comment Share on other sites More sharing options...
cv8z Member 125 Member For: 17y 10m 5d Location: Brisvagas Posted 21/06/10 04:51 AM Author Share Posted 21/06/10 04:51 AM (edited) ha ha ha ha 4000rwkw ha ha 400rwkwOk guys I lied a bit in my post, as I was typing quickly as im at work.The car is a BF Typhoon R Spec T56The car has been off the road for 2 years as its being fully rebuilt (repairable write off)The panel beater washed down the engine with a fire hose about 1.5 years ago, while the intake and exhaust manifold was off being powder coated.When the car was put on the Dyno for the tune, the engine was siezed due to the water in 5 and 6 cylinder.After alot of oil was left in the bore to try and unsieze the engine # 5 came out ok but # 6 when being pressed out (yes press out) cracked the lock.So I am needing another engine but dont want ta waste time or money searching for a FPV long engine if a XR6T engine has the same internals.I have been told the FPV has stronge rods and lower compression ratios.Any one with real speacs please helpCheers Edited 21/06/10 04:58 AM by cv8z Link to comment Share on other sites More sharing options...
Henz Tampon inserted, Auto Acquired, next purchase a new handbag Donating Members 9,946 Member For: 16y 1m 4d Gender: Male Location: Vic Posted 21/06/10 06:07 AM Share Posted 21/06/10 06:07 AM Typhoons and anything after after 06/06 in the xr6t range have the same motors in the B range. Does that clear it up for you?The FG F6 motors have Forged pistons, and I think the fg xr motors are just the same as the 06/06 motors? Link to comment Share on other sites More sharing options...
cv8z Member 125 Member For: 17y 10m 5d Location: Brisvagas Posted 21/06/10 10:57 AM Author Share Posted 21/06/10 10:57 AM (edited) Thanks heaps henzBasicly after 06/06 all the motors were the same?Except the FPV FG series But the FG XR series all had the same engines as the 06/06 B series?I think I have it all nowCheers Edited 22/06/10 07:26 AM by RHR No need to quote above post. USE FAST REPLY Link to comment Share on other sites More sharing options...
hawlass Silver Donating Members 1,161 Member For: 16y 5m 15d Gender: Male Location: left right out Posted 22/06/10 06:51 AM Share Posted 22/06/10 06:51 AM At exactly what point in 06/06 did the change over occur? mine is a 06/06 build. Dont know wheather it was very early or very late 06/06 though. Would ford be of any help in this! Link to comment Share on other sites More sharing options...
razza0066 Member 13 Member For: 13y 11m 15d Gender: Male Posted 22/06/10 07:12 AM Share Posted 22/06/10 07:12 AM I got told the same thing about them being stronger as I am searching for motor to, because I shot a rod out the side of my block. When I called ford today the guy on the phone told me a f6 short motor was 3200 and that they were the same from 05 to the end of production, but he didnt sound like he new what he was talking about so I am just getting a block and getting it built up Link to comment Share on other sites More sharing options...
