Guest Scott Greco Guests Posted 28/03/10 09:48 AM Share Posted 28/03/10 09:48 AM I fitted duel zone to my ba xr6 turbo to day every thing works but secrity error come up on the icc screen I have tryed every thing to to get it to start over when I checked the pcm for codes it comes up with p1260 theft detected engine disableand I also checked codes for the cluster and it has a b1342 ecu defect what the hell is the go hear I tryed to program my keys but itg still wont starthear is the list of parts I fitted if it helps* green BEM* duel zone icc unit* hi series cluster fpv if it maters* LH mirror with air temp sensor* lhf door harness * sun load sensor* HIM programed to duelzone * auto lights cobination switch* I did not replace the dash harness because it has the same part number as a ba mk11 with duel zone fitted can some one plz help me with this Link to comment Share on other sites More sharing options...
Panda Eyes flame magnet Gold Donating Members 5,673 Member For: 15y 11m 2d Gender: Male Location: adelaide hills- 'race air' central Posted 28/03/10 10:04 AM Share Posted 28/03/10 10:04 AM (edited) it may be the icc unit and the computer/ bem dont match.if you remove the icc, the car wont start till the big white plug on the back is connected back in.the icc is actually part of the security. if the car and icc are not compatible security code wise, that's prol the problem. perhaps the bem/ computer needs to be from the same car the icc came from? someone verify? Edited 28/03/10 10:05 AM by fordriver1 Link to comment Share on other sites More sharing options...
5lYBA Member 57 Member For: 15y 22d Gender: Male Location: Sunshine Coast Posted 28/03/10 10:07 AM Share Posted 28/03/10 10:07 AM Ive been told you have to get it programmed at Ford when you do the dual zone upgrade? Link to comment Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 19y 11m 24d Gender: Male Location: Brisbane Posted 28/03/10 10:20 AM Share Posted 28/03/10 10:20 AM Although someone did mention on here a while back that it could be done...but offered no elaboration. But yeah basically the bem and icc need to learn to like each other otherwise it thinks you're up to no good and won't let you start the car. Link to comment Share on other sites More sharing options...
Guest Scott Greco Guests Posted 28/03/10 10:32 AM Share Posted 28/03/10 10:32 AM the bem and icc come out of the same car but still no good I tryed putting my old icc unit and bem in and it still wont start so im lost and confused Link to comment Share on other sites More sharing options...
icer Banned 2,335 Member For: 14y 9m 1d Gender: Male Location: Aspendale, Vic. Posted 28/03/10 11:11 AM Share Posted 28/03/10 11:11 AM try keep car off, get to security code screen on icc (press volume button if u have to) then hold down FM and MENU for 5 seconds.See if that trick helps you in any way Link to comment Share on other sites More sharing options...
Guest Scott Greco Guests Posted 28/03/10 11:21 AM Share Posted 28/03/10 11:21 AM cheers I will try that lucky the car is not on the road at the moment I want to keep if away from a ford work shop if I can it not quite std any more and a bit hard to get it there Link to comment Share on other sites More sharing options...
Paul@eliteauto Member 843 Member For: 17y 7m 18d Gender: Male Location: Brisbane Posted 28/03/10 11:25 AM Share Posted 28/03/10 11:25 AM Pretty sure Ford are the only people who can reprogram it. Link to comment Share on other sites More sharing options...
Guest Scott Greco Guests Posted 28/03/10 11:45 AM Share Posted 28/03/10 11:45 AM oh well looks like I will have to ring c if they will come round to the work shop with the ids and get this thing cranking cheers for your help guys Link to comment Share on other sites More sharing options...
sexual harrassment panda I see a red door and I want to paint it black Donating Members 5,919 Member For: 14y 5m 24d Gender: Male Location: Far north queensland Posted 28/03/10 07:51 PM Share Posted 28/03/10 07:51 PM cheers I will try that lucky the car is not on the road at the moment I want to keep if away from a ford work shop if I can it not quite std any more and a bit hard to get it thereNot quite standard - that turbo could swallow my turbo whole Any luck yet? Link to comment Share on other sites More sharing options...
