Why Wont My Ba Start After Dual Zone Upgrade
Guest Scott Greco
Guest Scott Greco
  • Guests
I fitted duel zone to my ba xr6 turbo to day every thing works but secrity error come up on the icc screen I have tryed every thing to to get it to start over when I checked the pcm for codes it comes up with p1260 theft detected engine disable
and I also checked codes for the cluster and it has a b1342 ecu defect what the hell is the go hear I tryed to program my keys but itg still wont start
hear is the list of parts I fitted if it helps
* green BEM
* duel zone icc unit
* hi series cluster fpv if it maters
* LH mirror with air temp sensor
* lhf door harness
* sun load sensor
* HIM programed to duelzone
* auto lights cobination switch
* I did not replace the dash harness because it has the same part number as a ba mk11 with duel zone fitted
can some one plz help me with this
  • flame magnet
  • Member For: 15y 11m 3d
it may be the icc unit and the computer/ bem dont match.
if you remove the icc, the car wont start till the big white plug on the back is connected back in.
the icc is actually part of the security. if the car and icc are not compatible security code wise, that's prol the problem.
perhaps the bem/ computer needs to be from the same car the icc came from? someone verify?
Edited by fordriver1
  • Sucker
  • Moderating Team
  • Member For: 19y 11m 25d
:w00t2:
Although someone did mention on here a while back that it could be done...but offered no elaboration. But yeah basically the bem and icc need to learn to like each other otherwise it thinks you're up to no good and won't let you start the car. :spit:
Guest Scott Greco
  • Guests
the bem and icc come out of the same car but still no good I tryed putting my old icc unit and bem in and it still wont start so im lost and confused
  • Banned
  • Member For: 14y 9m 2d
try keep car off, get to security code screen on icc (press volume button if u have to) then hold down FM and MENU for 5 seconds.
See if that trick helps you in any way
Guest Scott Greco
  • Guests
cheers I will try that lucky the car is not on the road at the moment I want to keep if away from a ford work shop if I can it not quite std any more and a bit hard to get it there
Guest Scott Greco
  • Guests
oh well looks like I will have to ring c if they will come round to the work shop with the ids and get this thing cranking cheers for your help guys
  • Member For: 14y 5m 24d
Not quite standard - that turbo could swallow my turbo whole :fishin:
Any luck yet?
