dajsilman New Member 1 Member For: 4y 11m 16d Posted 03/05/19 01:01 PM Share Posted 03/05/19 01:01 PM I have the hurst shifter and the tr6060 in a ba. the old boot is totalled and the only ones I have found have a round metal ring at the top which sits very high up the hurst shaft. I might just make my own or something. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,291 Member For: 16y 9d Gender: Male Location: Melbourne Posted 03/05/19 01:05 PM Share Posted 03/05/19 01:05 PM you have to take the metal ring off, basically, then install the plastic bit, that comes with the hurst stick, into the standard boot. 1 Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 23d Gender: Male Location: Perth Posted 03/05/19 02:30 PM Share Posted 03/05/19 02:30 PM https://www.ebay.com.au/itm/Hurst-Shifter-Stick-Rubber-Oval-Grommet-Boot-Support-Retainer-for-Mustang-Camaro/361424243443?hash=item5426904af3:g:m48AAMXQnYJQ9dDO Link to comment Share on other sites More sharing options...
OZYWALKER XR50T Gold Donating Members 2,795 Member For: 10y 11m 18d Gender: Male Location: Western Sydney Posted 03/05/19 09:26 PM Share Posted 03/05/19 09:26 PM Works just as well with a cable tie by itself I reckon. That rubber grommet reforms where the cable tie head sits. Link to comment Share on other sites More sharing options...
OZYWALKER XR50T Gold Donating Members 2,795 Member For: 10y 11m 18d Gender: Male Location: Western Sydney Posted 12/05/19 12:36 PM Share Posted 12/05/19 12:36 PM So who's tried more than one short shifter?I much prefer the feel of 1-6 with the core short shifter over the mal wood ultimate street shifter. But given the ultimate street shifter goes into reverse without force I'll stick with it. The core shifter feels like it has stiffer springs in it and gives a firmer shift. Both go through the gears real nice but I much prefer the firmer feel of the core shifter.Hoping I'll be able to tinker with the core shifter to make it work a bit better.So who's tried the GM Rip shifter? Thoughts? Link to comment Share on other sites More sharing options...
HI PSI Member 1,567 Member For: 17y 10m 25d Gender: Male Location: Central Queensland Posted 12/05/19 09:51 PM Share Posted 12/05/19 09:51 PM As far as I know, the Mal Wood shifter does not have a spring. The Magnum's have a detent spring, which is a sealed unit that screws into the R/H side on the gearbox. It is this spring that gives you resistance and gate pressure. I think that the difference in the height of the shifters that you're using, is affecting the leverage on the detent spring and using less resistance to push through it... See link for a pic of a dentent spring Detent spring Link to comment Share on other sites More sharing options...
masda74 To Loud Gold Donating Members 4,112 Member For: 12y 4m 19d Gender: Male Location: WA, Perth Posted 13/05/19 12:24 AM Share Posted 13/05/19 12:24 AM I have the aeroflow short shifter and you feel and hear everything from the Gearbox now, especially with the new clutch. With the stock cluck it didn't feel as bad, but still with the stock gear stick you had that solid feel and no noise, due to the black rubber separating the gear lever from the block that bolts to the shifter. That block of rubber is solid and it is the reason why you don't hear or feel anything from the gearbox. You can actually see the rubber in this picture, even though it is painted. It is where the lever meets the solid block on the left side of the picture. The fact that it is painted is what makes that block look like it is one solid piece. I have been trying to replicate that feel for a few years now with different stuff, with no success. Link to comment Share on other sites More sharing options...
OZYWALKER XR50T Gold Donating Members 2,795 Member For: 10y 11m 18d Gender: Male Location: Western Sydney Posted 13/05/19 02:18 AM Share Posted 13/05/19 02:18 AM As far as I know, the Mal Wood shifter does not have a spring. The Magnum's have a detent spring, which is a sealed unit that screws into the R/H side on the gearbox. It is this spring that gives you resistance and gate pressure. I think that the difference in the height of the shifters that you're using, is affecting the leverage on the detent spring and using less resistance to push through it... See link for a pic of a dentent spring Detent springIt definately does, to center the shifter when in neutral and help pull it across when going 2-3 etc. Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 23d Gender: Male Location: Perth Posted 13/05/19 01:59 PM Share Posted 13/05/19 01:59 PM (edited) The stronger spring brings the stick back to centre so 3rd is straight up. The most important shift 2nd to 3rd Short throw is achieved by changing the pivot point Edited 13/05/19 02:07 PM by arronm Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 23d Gender: Male Location: Perth Posted 13/05/19 02:40 PM Share Posted 13/05/19 02:40 PM Shifter springs. Stronger centres better 1 Link to comment Share on other sites More sharing options...
