Barnesy Donating Members 210 Member For: 15y 3m 3d Gender: Male Location: Brisbane Posted 21/12/09 02:51 AM Share Posted 21/12/09 02:51 AM I was wanting to find out specs for the premium sound amp (Sanyo - formally FMS audio), so I contacted Ford and replied with "Unfortunately, Ford Australia is unable to provide technical advice via telephone or written communication. We suggest that contact an Authorised Ford Dealership or Sanyo directly for any technical advice."So I decided to email Sanyo Australia, and got a guy who did a bit of research and passed on my queries to Sanyo (Japan) where the Ford amps were made.They got back to me with the specs for the Model# 14788100 premium sound amp:Standard Output:100W(THD1%@30Hz)Maximum Output:150W(THD10%@30Hz)Number of channel: 1chOperation Voltage Range:8-16VPower Source: 14.3V DC Negative GroundSpeaker Load: 4ohmOperation Temp. Range:-10-55℃S/N Ratio: 70dBSize[mm]:150(D) x 267(W) x 55(H)Weight:1.6kg Link to comment Share on other sites More sharing options...
smicky Go Pies!!! Donating Members 2,852 Member For: 16y 2m 7d Gender: Male Location: Vic Somewhere - Sometimes NSW Posted 22/12/09 03:59 AM Share Posted 22/12/09 03:59 AM "Number of channel: 1ch"Huh?So your telling me is a single mono block channel amp?hhhhmmmmNot so sure about that...I was lead to believe it was a 5ch amp...FR, FL, RR, RL, + SUB!hhhhmmmmm"Speaker Load: 4ohm"Are they advising the amp is only 4ohm stable, or rather the single channel is running at 4 ohm with a "Panasonic" driver/sub? Link to comment Share on other sites More sharing options...
Barnesy Donating Members 210 Member For: 15y 3m 3d Gender: Male Location: Brisbane Posted 22/12/09 04:22 AM Author Share Posted 22/12/09 04:22 AM I was always under the impression that at least the BA premium sound was only driving the sub.As said above specs came direct from Sanyo Japan, whether they are to be taken as fact is another thing, maybe someone more technically minded with stereo can confirm there figures sound about right. Link to comment Share on other sites More sharing options...
smicky Go Pies!!! Donating Members 2,852 Member For: 16y 2m 7d Gender: Male Location: Vic Somewhere - Sometimes NSW Posted 22/12/09 05:13 AM Share Posted 22/12/09 05:13 AM Power figures may be correct...No question there...100w at 1% @ 4ohm could be right...around 50w @ 8 ohms.... so average as we thought...However I thought (as mentioned) the amp was powering the speakers also?I havent bothered to look since buying the F6 - if I start looking, then I start thinking, then thinking becomes buying, and buying becomes playing... and well the cycle doesnt really stop for me... Link to comment Share on other sites More sharing options...
NitroXR6T Member 28 Member For: 15y 10m 12d Posted 01/01/10 04:12 AM Share Posted 01/01/10 04:12 AM from ef/el and maybe even earlier, the amps only power the sub. Head unit/icc does the rest. Link to comment Share on other sites More sharing options...
accelrate Donating Members 47 Member For: 15y 8m 1d Posted 14/01/10 12:59 AM Share Posted 14/01/10 12:59 AM I don't know about BA\BF, but the FGs rears definately aren't powered by the amp. I disconneted the power from it. As for EF/ELs, I used to have an NL (same thing really) with premo sound and it DEFINATELY powered the rears. It was also a 4ch amp, with RCA connectors and the like. The sub was powered in bridge mode from one input (never heard stock sub as it was on gas and it was taken out to make room). I now have an FG and if someone has the wiring diagram for the amp that'd be great, cos if it has line level that'd be wicked (unfortunatly no line level for the fronts/rears.) Link to comment Share on other sites More sharing options...
smicky Go Pies!!! Donating Members 2,852 Member For: 16y 2m 7d Gender: Male Location: Vic Somewhere - Sometimes NSW Posted 14/01/10 01:26 AM Share Posted 14/01/10 01:26 AM NL - minus sub... Old man has a Concord Fairlane, and we had it converted to GAS... first thing after the tank was put in, we boxed out the sub behide the rear seat... moved the stacker to one side, sub on the other and it was like there was no take there (exception to 1/3 of the boot space missing)... Link to comment Share on other sites More sharing options...
XtRmn8 570Nm @1800rpm Donating Members 2,441 Member For: 20y 7m 2d Gender: Male Location: Perth, WA Posted 14/01/10 01:31 AM Share Posted 14/01/10 01:31 AM The amp only power the subwoofer in the factory premium audio. The rest of the speakers run of the head unit. Link to comment Share on other sites More sharing options...
