EnricoPalazzo Member 84 Member For: 18y 7m 10d Posted 08/11/09 07:28 AM Share Posted 08/11/09 07:28 AM Hmmm,Just read all of this...My Fg F6 does do what the guy was suggesting.If I disengage DSC, ie press down the button and it will say DSC off, power is still being cut when I get the rear end out.What is interesting is someone commented that if the DSC light flashes while DSC disengaged, something is wrong. This is happening to me and it is making the car annoying to drive in a spirited manner. I think ill talk to Ford about this. Anyone else have this issue or just me? Link to comment Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 19y 11m 3d Gender: Male Location: Brisbane Posted 08/11/09 10:24 AM Share Posted 08/11/09 10:24 AM Stupid question, but it's not the LSD doing it's work that you guys are confusing with the electronic intervention is it? Link to comment Share on other sites More sharing options...
Ace blind leading the blind Member 3,657 Member For: 15y 6m 17d Gender: Male Location: Mt Alford, Queensland Posted 08/11/09 10:49 AM Share Posted 08/11/09 10:49 AM actually I think the issue you guys are having is similar to the problem hiro had with his ute - apparently its something in the transmission causing the problem - enricco is yours auto??? Link to comment Share on other sites More sharing options...
dashturbo Donating Members 280 Member For: 15y 7m 20d Gender: Male Location: Watsonia Posted 09/11/09 01:11 AM Share Posted 09/11/09 01:11 AM sounds to me like what your saying is that the brakes on the trailer come on when you hit a bump... sounds pretty normal to me.If the trailer is braked it usually works off a moving ball mount, so that when your trailer starts to push the car, like down hill, the brakes come on, if however you hit a bump the trailer brakes will get a thump through the mount and jam them on for a second, probably not that dangerous because it will straighten up the trailer by pulling the two straight again.The other possibility is that the FG has trailer assist, where the DSC changes when a trailer is plugged into the socket. I don't know if the FG has it but that could explain a little.The wheel position is not measured by DSC, just the wheel speed. So a vertical movement of the wheel wont be picked up on a falcon.I have trouble believing that Traction control can be turned off without DSC anyway, considering its the same thing, except DSC contains a YAW sensor to tell what the vehicle is doing momentum wise. Link to comment Share on other sites More sharing options...
EnricoPalazzo Member 84 Member For: 18y 7m 10d Posted 09/11/09 11:21 AM Share Posted 09/11/09 11:21 AM Yep mines an auto, and it probably is an issue with the tranny as my tuner is still trying to sort out the changes to make it crisp and not cut power. Link to comment Share on other sites More sharing options...
Ace blind leading the blind Member 3,657 Member For: 15y 6m 17d Gender: Male Location: Mt Alford, Queensland Posted 09/11/09 11:22 AM Share Posted 09/11/09 11:22 AM yeah hiro is definately having that problem too - so I would say its nothing to do with dsc and more to do with tranny Link to comment Share on other sites More sharing options...
Caghan Member 50 Member For: 17y 3m Posted 13/01/10 07:57 AM Share Posted 13/01/10 07:57 AM they must have really upped the technological advances with the 09 models. by the sounds of things there are like 10 variations of DSC's controlling the car. Link to comment Share on other sites More sharing options...
Ryan soanezy New Member 2 Member For: 4y 10m 23d Posted 05/05/19 08:26 AM Share Posted 05/05/19 08:26 AM In my 2009 fg xr6t sedan despite weather the light is on the dash or off it cuts power under straight line acceleration the same this dosnt seem right to me Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 1d Gender: Male Location: Perth Posted 05/05/19 08:40 AM Share Posted 05/05/19 08:40 AM You have to hold down the LEM. look at 3.25 minutes. Link to comment Share on other sites More sharing options...
Ryan soanezy New Member 2 Member For: 4y 10m 23d Posted 05/05/19 06:50 PM Share Posted 05/05/19 06:50 PM If I hold mine down for just a few seconds the light comes on but makes no difference Link to comment Share on other sites More sharing options...
