nik38 Member 9 Member For: 14y 8m 27d Posted 23/10/09 12:47 PM Share Posted 23/10/09 12:47 PM has anybody been successful in disabling stability control via the pcm,thanks. Link to comment Share on other sites More sharing options...
Venom XR6 Member 1,460 Member For: 20y 11m 24d Location: Geelong Victoria Posted 24/10/09 01:22 AM Share Posted 24/10/09 01:22 AM Why not just push the button to turn it off?Isn't it push once to turn off TC, push again to turn off both. Link to comment Share on other sites More sharing options...
nik38 Member 9 Member For: 14y 8m 27d Posted 25/10/09 12:06 AM Author Share Posted 25/10/09 12:06 AM hi v, as far as my t ute is concerned,09 fg,stability control is not switchable. The dsc switch allows traction control to be disabled,however the stability control remains activated and is unswitchable. Im starting to think that lowering the vehicle may be a way to delay it from coming in so early,but would prefer not to drop it and at this stage I am unable to find a tuner who knows how to disable it via the pcm. I wont get a flash tune unless im guarenteed they can remove stability control. Link to comment Share on other sites More sharing options...
Venom XR6 Member 1,460 Member For: 20y 11m 24d Location: Geelong Victoria Posted 01/11/09 09:45 AM Share Posted 01/11/09 09:45 AM (edited) Ford do not sell a vehicle that has an unswitchable DSC. You can turn it off. Read the owners manual.You either need to press the button twice or hold it down for a few secs to turn it off. Edited 01/11/09 09:46 AM by Venom XR6 Link to comment Share on other sites More sharing options...
trevs Member 781 Member For: 16y 11m 29d Gender: Male Location: balmain Posted 01/11/09 10:58 AM Share Posted 01/11/09 10:58 AM I dont see why somebody would want DSC. removed on a street car my cars tuned has a tad over 300rwkw is lowered on bilstein shocks bigger front and rear sway bars has 19inch after market wheels and the dsc still works although not as good as it did standard its still saved my ass a few times in the wet and dry I can understand not wanting it and traction control at the track and its as simple as holding down the botton for 3 secs or so and they both turn off in a bf at least anyway if your driving your car on the street hard enough to need the dsc and traction off all the time your either going to end up with your car in the police impound or lose your licensecheers trev Link to comment Share on other sites More sharing options...
nik38 Member 9 Member For: 14y 8m 27d Posted 04/11/09 08:53 AM Author Share Posted 04/11/09 08:53 AM Hi T, I was under the impression that stability control was switchable on my ute and that was a major factor when I bought it,as I did not want it. So, at its 3k check I informed ford service that stability control was not turning off when the dsc symbol on the dash told me, dsc off. I was then informed by ford service that when the dsc was deactivated it was not meant to turn off stability control, so that means its false advertising or ford service did not want to fix my car. However, rather than pursue a headache with ford I was hoping a tuner or someone on this site knows whether or not stability control can be disabled via the pcm. My reasons for wanting full control of my car have nothing to do with impounding the vehicle or losing my licence. Stability control may not be a issue for you but it is for me. Link to comment Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 19y 11m 25d Gender: Male Location: Brisbane Posted 04/11/09 11:47 AM Share Posted 04/11/09 11:47 AM ...when the dsc was deactivated it was not meant to turn off stability control...Umm...DSC is (dynamic) stability control Link to comment Share on other sites More sharing options...
nik38 Member 9 Member For: 14y 8m 27d Posted 05/11/09 07:42 AM Author Share Posted 05/11/09 07:42 AM guys, please dont insult my intelligence. I know what the friggin manual says and I know that turning the dsc switch off is only disabling traction control in my car and not disabling any other part of the stability control which includes braking and engine control/throttle control which it should be cutting the whole lot out when you use the dsc switch as per owners manual. That is why I brought the issue up with ford and I am simply telling you what they told me. I have asked whether or not anyone has disabled the dsc via the pcm. I have not asked how to use the friggin switch nor have I asked for advise on whether I should be turning it off or not. So please, as a fellow ford member who respects others can you please read the question I am asking before you answer. Regards nik,fellow ford member. Link to comment Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 19y 11m 25d Gender: Male Location: Brisbane Posted 05/11/09 07:52 AM Share Posted 05/11/09 07:52 AM I quoted/questioned your own words FFS...just wanted to make sure you knew exactly what you were talking about. Terribly sorry if this has offended you. I don't know of anyone that's done what you're asking...your best bet would be to call a tuner and ask them. Link to comment Share on other sites More sharing options...
ZAP No boost, no bottle, just my foot on the throttle! Lifetime Members 7,935 Member For: 20y 2m 5d Gender: Male Location: Sydney Posted 05/11/09 08:36 AM Share Posted 05/11/09 08:36 AM Nik,I think you are not being told the truth.The DSC and Traction control is switched OFF if you hold the button down for a few seconds. You cannot just turn off one, they will both turn on/off together.The orange light with the car skidding will pop up on the dash. This means you have no electronic fun police.My FG has been on the track and I can confirm that the DSC is OFF when you do the above.As for the tuner disabling this, I do not believe it is possible as the DSC is part of the BEM and has not been cracked yet.As others have mentioned, I do not know why you would want this permenantly disabled, as it is a very important safety feature of the car.You should also reread what you have written and see that it is a tad cryptic, we are here to help, but will not put up with crap. Link to comment Share on other sites More sharing options...
