SuckSqueezeBangBlow ʎǝʞuoɯ ɹoıuǝs Donating Members 1,808 Member For: 15y 3m 12d Gender: Male Posted 15/10/09 06:58 AM Share Posted 15/10/09 06:58 AM Hi, so although my car only had 26000kms when I bought it I don't know if the previous owner idled it down after a thrash or not.To find out if my oil feed line has carbon build up I thought I could either 1. undo the oil feed line and run the oil into a measuring container to work out a rough litres per hour or minute or whatever, or 2. undo the drain into the pan and do the same.I guess my question is, is there a set figure on how much flow the oil feed should provide given there is a restrictor at the entrance to the CHRA? or should I just buy ETM's aftermarket line? I just like the stock look so perhaps I could run the feed around the back of the head instead?just thinking/writing out loud, any ideas appreciated.Jono Link to comment Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 18y 8m 21d Gender: Male Location: OZ Posted 15/10/09 08:45 AM Share Posted 15/10/09 08:45 AM Just replace the standard filter (and line if you're worried) in the first instance. But in saying that, it's such a PITA job that I'd just spend the money and go ETM if I were to do it again Link to comment Share on other sites More sharing options...
SuckSqueezeBangBlow ʎǝʞuoɯ ɹoıuǝs Donating Members 1,808 Member For: 15y 3m 12d Gender: Male Posted 15/10/09 08:54 AM Author Share Posted 15/10/09 08:54 AM (edited) if I was to spend any $$$ I'd rather just get ETMs braided lines I think Edited 15/10/09 08:54 AM by JC807 Link to comment Share on other sites More sharing options...
hypnodoc It's All In Your Mind Gold Donating Members 2,198 Member For: 20y 4m 28d Gender: Male Location: Melbourne Posted 15/10/09 09:22 AM Share Posted 15/10/09 09:22 AM if I was to spend any $$$ I'd rather just get ETMs braided lines I thinkWell worth it IMHO. Looks great and puts a 100% end to the issue and any potential cooked oil blocking Link to comment Share on other sites More sharing options...
PHANTMXR6 It's not a MKI! Member 1,742 Member For: 15y 9m 9d Gender: Male Location: Earth Posted 15/10/09 11:01 AM Share Posted 15/10/09 11:01 AM The only 100% end/cure to blocked turbo oil supply lines is regular servicing.You can fit any aftermarket supply line and screen, but if you don't service it you will still end up with the same result.The thing that causes failure is lack of regular servicing.If you fit an aftermarket supply line you will not decrease the chances of this happening. All you will be doing is making the screen easier to access. Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 2d Gender: Male Location: Perth Posted 15/10/09 01:27 PM Share Posted 15/10/09 01:27 PM Here is how it works. If you do not regularly change the oil or do a lot of motorsport which excessively overheats the oil, this will cause the oil supply line filter to start to block. This reduces the oil flow through the oil line which results in two things 1) reduced oil to the turbo. 2) the reduced flow through the oil line ( which actually cools the line as it flows through it)starts to overheat the oil causing it to oxidize and leave deposits on the inside of the oil line at the hottest section next to the turbo. This cycle continues until either the filter blocks or the oil line blocks, either way two minutes later no more turbo bearings. The simplest thing to do is remove the inline turbo oil filter ( the turbo doesnt require the filter after approx 2000kms, as its only there as Garret wouldnt warrant the turbos, as Ford had a problem with not being able to remove all casting remnants and this caused premature turbo bearing failure) and change your oil regularly. Arron P.S -- removing the factory inline turbo filter may void your warranty. But we all know once you modify your engine or its components in any way you have no warranty any rate. Link to comment Share on other sites More sharing options...
Smoke them tyres Member 557 Member For: 16y 3m 7d Gender: Male Location: Brisbane Posted 15/10/09 01:30 PM Share Posted 15/10/09 01:30 PM The coking in the line is probably because the oil flow is already reduced by that stupid std inline filter. It is only there to catch any crud when the engine is new. Now that it's not it should be sent packing.I removed mine. This filter sits after the main oil filter. Why filter filtered oil and create a headache for no gain? The surface area of the filter in the feed line would be in the mm2........pointless. Link to comment Share on other sites More sharing options...
kirjo Member 113 Member For: 14y 9m 13d Gender: Male Location: Brisbane Posted 15/10/09 03:31 PM Share Posted 15/10/09 03:31 PM I agree the factory supply screen is a joke. Look at it! The ETM kit is worth every cent, and IMO is one of those 'must do' mods! Link to comment Share on other sites More sharing options...
smXR6 Member 206 Member For: 15y 7m 27d Gender: Male Location: Noble park Posted 15/10/09 07:44 PM Share Posted 15/10/09 07:44 PM do you guys reccomend just replacing the filter with a brand new one or taking the screen filter out so it doesnt run a filter ? gonna do mine soon so wanna no the best option cheers Link to comment Share on other sites More sharing options...
PHANTMXR6 It's not a MKI! Member 1,742 Member For: 15y 9m 9d Gender: Male Location: Earth Posted 16/10/09 12:58 AM Share Posted 16/10/09 12:58 AM Everyone will have their own opinion smXR6.If you're asking me, just replace the fitting that houses the screen when you service it.Depending on where you buy it, it's around $60. You can try and remove it if you like, but the chances of damaging it when trying to get it out are quite high.It's your money at the end of the day. Link to comment Share on other sites More sharing options...
