  • Member For: 17y 1m 18d
since when is the rev limiter set to 5500? should be closer to around 6200
as for the cutting out I have recently had the same thing. I changed coils, plugs and fuel filter then finally changed the fuel pump and havent seemed to have an issue since. mine was leaning out quite badly in top end though (stock tune and not doing it every time) and sometimes stuttering at idle.
take it to a proper mechanic for servicing and get it on a dyno to check AFRs
  • Replies 21
Posted Images
  • iTs alL DaRDy........
  • Member For: 17y 10m 14d
its the rev limiter, im pretty sure its set to 5600 but if u get a tune done I think it changes to a higher figure set by the tuner.
just double checked some of the stock tunes have here. BA1 and BA2, auto and manual, turbo and NA all have the rev limiter set at 6200 not 5600. the only ones that are different are the ones that have been tuned.
  • Member For: 18y 4m 13d
Before I sold my xr6t it was pretty much stock, redline was 5650rpm,
  • Member For: 17y 4m 8d
I had this issue ware BA auto was hitting a wall 5200 5500 rezs depending how I put the power down. changed plugs fule filter. it turned out to be my cat had that replaced no issue was fixed id check your cat.
both millers and my car go to 6200 limit. if you car was not going to 6200 it was not running right.
Standard straight from the factory in mk1 the rev limit was 5650rpm in the manuals, the autos used to flair slightly during shift, when the mk11 came out is was the same and that's when the phoon came out with bigger bottom end, the mk11 xrt and the phoon shared the bigger rods, however the phoon had slightly less compression( 8.64:1 as apposed to the xr6t 8.7:1) I know this cause Im reading the BA MK11 phoon,GT and GT-P new model introductory course I did when I was at ford. Normally the rev rev limit is increased from 5650rpm to 620rpm after heavy duty valve springs are fitted.
I see in your signiature under mods, you have valve springs listed, did you get them fitted or did you purchase the vehicle like that?
  • Member For: 16y 6m 16d
Took mine for a spin to see where she clunks out at...
Hit about 6200-6300 in-between probably before rev limiter kicked in...
It’s a BA MKII custom tuned and runs a T56 gearbox...
As for my rally and racing experience I wouldn't be recommending getting your revs that high for gear changes!
Keep it on about 5k and you will find the next gear level will come on stronger with boost than hitting 6200 which will cause your engine to dip in revs and try 2 come back harder putting a hell of a lot more strain on your engine.. everyone has their theory’s but that’s mine and it always works for me!
I agree, when I raced my car down the 1/4 mile when I was stock and then after the generic flash tune ( rev limit was still 5650rpm on each and I run my best time shifting at 5200rpm, launches were within .1 of each other, The power started to drop off after that anyway. Each of mates xr8 and xr6t mk1 I moded for them all had 5650 rpm rev limiter before the tunes, the xr8 went to 6200 after the tune, same with the xr6t but we changed the valve springs first.
Agreed 45T-XR
most people think u need to go all in to get the best response!
but that's not the case at all... smooth carefully selected gear shifts between 4800-5300 are your best options!
I drift a 180SX with 232rwkws as my little project and hobby.. but those little jap buggers really need a red light flash to get the best reaction..
but when driving a big V6 aussie muscle with an added turbo... no need to go all out!
hope this has helped some of you blokes out there looking to cut your time or win some off the line races!
Edited by tab
Quote removed
