Azid Rush Donating doesnt allow you to be an idiot! Member 692 Member For: 17y 2m 7d Gender: Male Location: Newcastle Posted 13/08/09 07:40 AM Share Posted 13/08/09 07:40 AM hey guyswent to hook up my new head deck today and for some reason doesnt seem to be any power going to the unit. Ive got it tapped into the blue plug behind fuse box like I did for my last stereo install and seems to be no power. Im sure the unit is in working order.Can someone tell me an alternative place to tap into power, earth and acc please Link to comment Share on other sites More sharing options...
sicklaser Member 183 Member For: 17y 7m 15d Location: Mackay QLD Posted 13/08/09 08:07 AM Share Posted 13/08/09 08:07 AM that's the best spot. test the wres for power with a test light or multimeter Link to comment Share on other sites More sharing options...
Azid Rush Donating doesnt allow you to be an idiot! Member 692 Member For: 17y 2m 7d Gender: Male Location: Newcastle Posted 13/08/09 08:24 AM Author Share Posted 13/08/09 08:24 AM yeh I cant find my test lightwhat is that plug actually for? It is possible that there isnt power running through it now?alternatively is there another place to tap into them Link to comment Share on other sites More sharing options...
Azid Rush Donating doesnt allow you to be an idiot! Member 692 Member For: 17y 2m 7d Gender: Male Location: Newcastle Posted 14/08/09 05:20 AM Author Share Posted 14/08/09 05:20 AM nobody guys?I had a blown fuse which I replaced but still no power going to deck. Dont have a volt meter so I cant test wires but the connections are definately good and I had the deck checked out today and it definately working so its in the wiring somewhere.Can someone recommend a decent place to tap into 12v, acc and earth apart from blue plug behind fuse box Link to comment Share on other sites More sharing options...
ravenhard Donating Members 1,517 Member For: 16y 1m 21d Gender: Male Location: Blacktown! Posted 14/08/09 06:13 AM Share Posted 14/08/09 06:13 AM that blue plug behind the fuse panel is a good place to get power but are you sure you got the right 1. there is 4 connections in that plug.-power which has constant 12V-power on with accessories 12V-earth 0V-mute 5Vas for which ones which, couldnt remember that's why a voltmeter is handy Link to comment Share on other sites More sharing options...
Azid Rush Donating doesnt allow you to be an idiot! Member 692 Member For: 17y 2m 7d Gender: Male Location: Newcastle Posted 14/08/09 07:23 AM Author Share Posted 14/08/09 07:23 AM nah I got the right ones buddy ive done 4 stereos in ba's and bf's including twice on my own, this is the first time ive had problems with the plug not working though Link to comment Share on other sites More sharing options...
bjc Donating Members 2,812 Member For: 20y 7m 20d Gender: Male Location: Townsville Posted 14/08/09 07:41 AM Share Posted 14/08/09 07:41 AM (edited) Do you have both power and acc hooked up yet or just the power and earth as I found with some HU's that you need both acc and power hooked up for it to turn on?sounds simple but some miss this when they are testing. Also check both the fuse on the head unit and the fuses in the fuse box just incase. otherwise if all is good power wise its the earth or your deck is farked.Also if you have a 12v power supply you could test it on there first to make sure it works? Edited 14/08/09 07:42 AM by bjc Link to comment Share on other sites More sharing options...
sicklaser Member 183 Member For: 17y 7m 15d Location: Mackay QLD Posted 14/08/09 08:01 AM Share Posted 14/08/09 08:01 AM its gotta be the wires at the phone plug of another fuse. spend the $4 for a test light and save a lot of dicking around Link to comment Share on other sites More sharing options...
Azid Rush Donating doesnt allow you to be an idiot! Member 692 Member For: 17y 2m 7d Gender: Male Location: Newcastle Posted 14/08/09 08:18 AM Author Share Posted 14/08/09 08:18 AM yeh I found my test light ill give it a crack tomorrow and try and work it outhad power earth and acc all hooked up, took head deck into JB today and they connected it to their jvc harness and it powered up so it isnt deck, I replaced the phone fuse which was blown and checked all other fuses including head unit all fineso its in the wiring somewhere Link to comment Share on other sites More sharing options...
