sticman Member 3 Member For: 14y 2m Posted 23/02/10 08:13 AM Share Posted 23/02/10 08:13 AM Hi man,Great work on the conversion mate. Thanks heaps for the write-up too, its certainly answered some of my questions.I am planning a turbo conversion on a BA wagon this year. Would everything be similar to what you did???I am just starting to search for the needed parts, but as it will be my daily driver (also loaded with carpenters tools!) I am leaning towards a full front cut or engine + box out of a XR6t. I will get them both reco'd 1st and then search for the other necessary parts.Any advice??Thanks Link to comment Share on other sites More sharing options...
RHR BOOST Moderating Team 5,698 Member For: 20y 7m 18d Gender: Male Location: Southern Highlands NSW Posted 23/02/10 10:07 AM Share Posted 23/02/10 10:07 AM now that's a sleeper Link to comment Share on other sites More sharing options...
youngman13 Member 22 Member For: 15y 5m 11d Gender: Male Location: NSW Posted 13/03/10 03:23 AM Share Posted 13/03/10 03:23 AM Very impressive write-up mate. Well done Link to comment Share on other sites More sharing options...
bentles Member 121 Member For: 15y 6m 25d Gender: Male Location: melbourne Posted 17/05/10 10:17 PM Author Share Posted 17/05/10 10:17 PM (edited) Hi man,Great work on the conversion mate. Thanks heaps for the write-up too, its certainly answered some of my questions.I am planning a turbo conversion on a BA wagon this year. Would everything be similar to what you did???I am just starting to search for the needed parts, but as it will be my daily driver (also loaded with carpenters tools!) I am leaning towards a full front cut or engine + box out of a XR6t. I will get them both reco'd 1st and then search for the other necessary parts.Any advice??Thankssorry for the late reply, the best suggestion for your conversion would be to find a BA/BF ute write off with the looms and engine trans etc still all in good condition and just swap EVERYTHING.. BEM, PCM, full looms, motor auto, tail shaft, diff everything... then you wont need to code anything its just a case of bolt it all up, plug it all in, and the full drivetrain/electronics will just think its still in the ute. only problem I can see is maybe you might need to keep your bem because of rear door locking and tailgate locking etc... so you might needa use your bem and code pcm to bem... Edited 17/05/10 10:18 PM by bentles Link to comment Share on other sites More sharing options...
xd turbo Member 58 Member For: 15y 4m 7d Gender: Male Posted 18/05/10 05:30 AM Share Posted 18/05/10 05:30 AM (edited) Is ford the only people that can code pcm and bem??(Turbo wagon that's the sh#t) Edited 18/05/10 06:07 AM by RHR No need to quote above post. USE FAST REPLY Link to comment Share on other sites More sharing options...
matt47569 Member 39 Member For: 14y 5m 9d Posted 10/07/10 09:54 AM Share Posted 10/07/10 09:54 AM Do you have any pics of the intake manifold butterflys? how did you take them out? Link to comment Share on other sites More sharing options...
F6-GHIA Member 27 Member For: 14y 16d Posted 11/08/10 03:21 AM Share Posted 11/08/10 03:21 AM Sweet write up bentles..... .... when I did my conversion I tossed up splicing the front fusebox wiring loom from my BA GHIA, but ended up buying one off a turbo cause I wasn't able to source some of the broken wiring plugs that came with the engine package I got. Link to comment Share on other sites More sharing options...
zayd687 Member 74 Member For: 14y 3m 12d Posted 26/09/10 02:47 PM Share Posted 26/09/10 02:47 PM is there a cross member under the sump??how did you tap the sump?im lookin at doing this but im not sure if the sump has cross member below that's holding the block otherwise I could tap it on ramps? Link to comment Share on other sites More sharing options...
icer Banned 2,335 Member For: 14y 9m 6d Gender: Male Location: Aspendale, Vic. Posted 26/09/10 03:17 PM Share Posted 26/09/10 03:17 PM IS THE CAR STILL GOING STRONG? aNY MORE MODS/POWER? ( -caps) Link to comment Share on other sites More sharing options...
Relentless xr6t Member 20 Member For: 13y 4m 10d Gender: Male Location: liverpool Posted 09/01/11 08:18 AM Share Posted 09/01/11 08:18 AM yeah mate used na injectors they are the same as turbo ones, just different pressure fuel reg for the extra fuel needed.. and I used my old n/a fuel pump.was a pretty easy conversion for me, as im a ford technician lol, took from friday to monday on easter weekend with help from 1-2 mates for some things like guiding motor out taking off bonnet stripping 1 manifold while I do the other etc etc...if you are mechanical minded shouldnt have a single problem...hey im curently doing a whole xr6t engine swap on a ba 2003 I am fitting a 2005 ba xr6t motor in it I have all the wiring loom and ecu I am curently running my old na fuel pump I got the car running and seems to be making boost but when I try to come back to idle it starts misfiring I hold it at 2000 rpm and it clears up I have also got a couple of check engine lights just wondering if you had any of these problems and what you think also the wastegate control solinoid only needs to be wired up if you dont have the plugs in your car already also my speedo isnt working do you think that is because it thinks I have 3 73 diff gears when I have 3 45 open centre?? Link to comment Share on other sites More sharing options...
